Supernova incoming! ASI183 series released!
ASI183 series is the newest series in this year! good news it this series is released and will be ready for shipping at the end of this December!!
Introducing the ASI183 camera series, the most sensitivie cameras in ZWO history. Peak Q.E. of the mono sensor reaches 84%!
ASI183 series including 4 models:
ASI183MM Pro mono cooled camera  999USD
ASI183MC Pro color cooled camera  899USD
ASI183MM mono uncooled camera  699USD
ASI183MC color uncooled camera  599USD
If you place an order before 31th of this December, you will enjoy a Christmas discount of 50USD
Let’s take a look of the most important one:
ASI183MM Pro
183MM Pro1
183pro-logo
Diagonal 15.86 mm Approx. 20.48M-Effective Pixel Monochrome/Color CMOS Image Sensor
IMX183CQJ-4K-Sensor
▶High-Speed and High-Picture-Quality Rolling Shutter-Type Back-Illuminated CMOS Image Sensors
In the astronomic application field, Sony IMX183CLK-J (monochrome) and IMX183CQJ-J (color) sensors uses a very high sensitivity back-illuminated structure with high resolution 2.4 μm square unit pixel.  The optical size is 1 inch.
DDR Memory Buffer
The ASI183 Pro camera includes a 256MB DDR3 memory buffer to help improve data transfer reliability. Additionally, the use of a memory buffer minimizes amp-glow, which is caused by the slow transfer speeds when the camera is used with a USB 2.0 port.
DDR3
DDR memory buffer is the main difference between ASI “Cool” and “Pro” cameras.
Astrophotography Performance
The ASI183 cameras has a very large full well capacity(15000e) for such small pixel size, 1.6e read noise @ 30DB, and 12stops dynamic range @ Gain=0. The ASI183 cameras also utilize firmware features to minimize amplifier glow for maximum performance in astrophotography.
183 Gain RN DR FW vs gainReliable Mechanics
ASI183 Pro has same mechanics as ASI1600 Pro. There are four screws that seal the sensor chamber. Our camera design has been extensively tested and is very stable.
Even when used in higher humidity environments, ASI183 Pro will still work fine without dew problems.
High Speed
Fast FPS can be used in solar and lunar imaging, as well as for live viewing/EAA.The high speed readout may also be used for real-time focusing, true lucky imaging of double stars and other small objects, planetary imaging of the major planets in the solar system, and much more.
10Bit ADC
5496×3672    19fps
3840×2160    41.04fps
1920×1080    80.10fps
1280×720      117.30fps
12bit ADC
5496×3672    19fps
3840×2160    36.12fps
1920×1080    70.48fps
1280×720      103.23fps
High QE
Sony’s back-illuminated Exmor R technology, giving it excellent Deep Sky performance. ASI183 QE peak reaches a remarkable 84%. In Ha channel, QE is still over 60%.
Having high QE means more of the light that enters your telescope and reaches the sensor is actually used. With 84% peak Q.E. and no less than ~50% within the visible spectrum, the ASI183 will utilize a high percentage of the light that reaches it, improving your signal quality.
IMX183
Dark Current
The dark current of the ASI183 is extremely low, based on our test results.
DCvsT-183
USB 3.0 Port & USB2.0 HUB
USB 3.0 Port: Provide 5Gb bandwidth to make it possible for ASI183 Pro to run at 19 fps (12bit, normal mode) or 19 fps (10bit, high speed mode)  at full resolution(20.18Mega).
Recommended cooler power supply: 12V @ 3-5A (or more) DC adapter (2.1×5.5mm, center pole positive). Also suitable: DC battery with 9-15V.
Using a battery with 9-15V is also suitable for the cooler power supply.
USB 2.0 HUB: can connect with various accessories, such as filter wheel, guide camera and electronic focuser, so you can better manage your cables. The ASI183 Pro includes two short 0.5m USB 2.0 cables. The integrated USB 2.0 hub is powered by the external power source if you connect one.
183MM Pro2
Cooling System
The ASI183 Pro has a 2-stage TEC cooling system that enables deep cooling (40°C-45°C below ambient). The cooler requires an external power supply, which is not included with the camera.
Connecting Drawing
connection183
  1. M43-T2 adapter
  2. Sony-T2 adapter
  3. 2”Filter (optional)
  4. EOS-T2 adapter
  5. T2 extender 11mm
  6. EOS adapter for EFW
  7. ZWO-EFW
  8. Nikon adapter for EFW
  9. 25” T-Mount
  10. 25” Filter (optional)
  11. M42-M48 adapter
  12. M42-M48 16.5mm extender
  13. M42-M42 21mm extender
  14. ZWO-OAG
  15. M42-M42 adapter(male)
  16. Focal reducer
  17. Nikon-T2 adapter
Mechanical Drawing
asi294-Mechanical-Drawing
What is in the box?
ASI183 Pro box includes all necessary cables, drivers, adapters, and manuals.
183-pro-package
Product review:
https://www.cloudynights.com/topic/599475-sony-imx183-mono-test-thread-asi-qhy-etc
Product link:
ASI183MM Pro
ASI183MC Pro
ASI183MM
ASI183MC
2 Comments
  • Brent
    Posted December 21, 2017 at 2:28 am
    very cool. what would you expect the results to be with this camera vs the asi 1600 mono on a 425mm/F2.1 hyperstar setup ??
    would it work as well as the 1600 at high gain (300) ?
    will the AR coated sensor make a noticeable difference over the 1600 ??
    thanks
    • Post Author
      Sam Wen
      Posted January 2, 2018 at 1:52 pm
      I think it should perform very well with such short focal ratio system
      AR coating must helps
