Tips and tricks for Solar imaging and processing with ASI290MM and ASI174 cameras
Let say that we have Solar H-alpha telescope and we would like to buy an appropriate camera for Solar imaging in H-alpha light to make our first image of the Sun in H-alpha light. What should we know?
Choosing the right ASI camera for Solar H-alpha imaging:
The best camera for Solar H-alpha imaging should have three main features:
  • a high frame rate capable for taking many frames together in a short video sequence,
  • camera should be monochrome and
  • camera should have a sensitive CMOS chip with high dynamic range.
Based on these features I would recommend two our models – ASI290MM or ASI174MM.
Tips and trick for Solar imaging and processing
Solar imaging and processing could be done in any astro image software: FireCapture, GenikaAstro, etc. The most important are the right camera settings. Set the camera Gain on 0 or on the lowest possible value, use few milliseconds (eg. 10, 15, 20 msec) exposure time and turn off the gamma value (50 and off). In general, keep the histogram values around 80-90%; if it is over 100% then some parts of the image are over-exposed and will appear as a bright white patch containing no surface details in the final image and the structure will be lost. Record the Sun when seeing is the best. Wait patiently and be ready to hit the record button during these times. You can also use Solar Scintillation Monitor (SSM) for real-time seeing monitoring and catch the best seeing.
sun-asi-camera-capturing
If the image suffers from Newton’s rings use a simple mechanical tilt adapter to remove them easy and quickly.
sun-asi-camera-newtonrings
Obtaining a precise focus is difficult but very important. No matter how much post-processing is done, an out of focus image will never as good as any image with good focus. I recommend you to use very innovative focus toll GenikaAstro and this step will become very easy and precise.
sun-asi-camera-focuscontrol_good
During the imaging session is recommended to take images for flat frame. A proper flat frame can remove dust from the camera chip and vignetting effect. The easiest way to do the flat is to get a very thin polythene bag and cover the front of the telescope or second option is to simply defocus the image. Take around 200-500 images and create the master flat in AutoStakkert!3 software. Please keep in mind that every camera rotation on additional ROI requires a new flat image.
flat-sun-halpha-asi-camera-290-174
Once a series of *.avi or *.ser video files are made they need to be processed in AutoStakkert!3 to give a single final image composed from the best frames of the video. The best dynamics of the chromosphere is guaranteed at 100-150 frames in one stack. A smaller alignment point (AP) size is better for finer details. Do not forget to use proper master flat frame image during the stacking process!
sun-asi-camera-stacking
Sharpening the stacked image can be achieved by many different techniques and softwares. The simplest and very effective method for sharpening is using the free software called ImPPG. ImPPG uses Lucy Richard deconvolution technique.  The Sigma slider can be finely tuned to estimate the point spread function of the particular image and the results can be seen quickly.
sun-asi-camera-sharpening-imppg
After stacking process select the best image file for post-processing and add an artificial color of a final image. In this step, you can use Adobe Photoshop or any similar image processing tool.
sun-asi-camera-photoshop
150-mm Solar telescope equipped with ASI290MM during the imaging near the sea. Your solar telescope should be mounted at the locations that minimizes the first meters of turbulence. Water surrounded locations show a minimal turbulence at low layers of atmosphere. The best seeing is usually in the morning from 10AM to 12AM.
solar-telescope-asi290-174
Our Sun is a fascinating target in H-alpha light even when the solar activity is low. If you will frequently observe the Sun, you will notice how active and dynamic it is from time to time. During imaging be creative and experiment with settings and processing techniques. There is no only one rule! We will be happy to hear your results and findings.
sun-asi-camera-174-290
8 Comments
  • Mr M
    Posted September 12, 2018 at 8:27 am
    Let’s say I do not have a Solar Alpha Telescope because I cannot afford it.
    What is the other cheaper option to obtain ‘decent’ images worth the expense?
    Thank you
    • Sean Wang
      Posted September 12, 2018 at 2:03 pm
      you may take a look of daylight solar accessories.
  • Robert Spannagel
    Posted April 25, 2020 at 5:24 pm
    I have the ASI 174MM for solar imaging. My scope is a Lunt LS 60THa & I have a double stack with that . My question is , I have an ASIAIR & thinking of getting the ASIAIR Pro, but what Inwant with that is better software control so I don’t have to use a laptop with SharpCap or FireCapture to image the sun. Does & is ASIAIR/ZWO ever going to put capture software on their ASIAIR so I can use an iPad or iPhone to adjust exposure, gamma, contrast, brightness etc? That would be awesome if the could. Let me know please….
    • Post Author
      Moson
      Posted April 26, 2020 at 7:30 am
      Sorry the ASIAIR PRO does not support planetary image. So is the sun image.
  • Joshua
    Posted January 10, 2021 at 4:11 am
    Since the ASiair Pro has been updated to capture video for planetary imaging, would the ASiair Pro work for Solar imaging as well?
    • Post Author
      Support@ZWO
      Posted January 11, 2021 at 9:06 am
      Yes.
  • oralpade
    Posted November 27, 2021 at 1:45 pm
    Have they progressed on the cameras for solar imaging since the last reply in 2018
    • sara.liu
      Posted December 17, 2021 at 7:14 am
      The ASI290MM and ASI174MM are the best choice for solar imaging currently.
