1. Wireless focus control
You are free to control EAF on your phone with the help of ASIAIR now.
2. Plug and play
As an HID USB device, EAF can be directly used and works well with ASICAP or ASIAIR, while it does not need any diver software installed.
Note: You’ll need to install ASCOM driver if you want to use more third-party software.
http://astronomy-imaging-camera.com/software-drivers
3. Highly integrated design
The motor and controller board are both integrated in the housing, which keeps the whole design very compact.
4. Stainless steel front panel
This material is not only abundant in texture and durability, but also able to ensure the stability of all connections.
5. No looseness
The set screws with blue teflon paste play important role in EAF through their anti-vibration and 100% separation preventing features.
6. Two in one
The multifunctional interface can be connected with the dedicated handle for manual focus and speed control, or access to the external temperature sensor to collect temperature data.
7. Status notification
You can judge your EAF’s working condition by the buzzing sound alerts. One voice for mission received, two voice for abnormal condition(e.g. EAF can not move).
EAF, the professional electronic automatic focus solution for astrophotography!
12 Comments
Max
I have a skywatcher black diamond ED80 for which I would want this autofocuser. But the ED80s Crayford Style focuser tends to slip under the load of my camera unless I tighten up the lock screw. It’s quite bad, I even have to hold the camera during focusing to be able to accurately achieve focus via Bhatinov mask. My question is: does the EAF compensate for a weak focuser or is it intended to make a good focuser better (ie enabling remote focus)?
Max
ZWO ASI Camera
The EAF Load 5kg, and focusing with Asiair or manual it
Bret
Is the EAF compatable with a Celestron SCT?
ZWO ASI Camera
The EAF is compatable with most Celestron, but i am not sure the Celestron SCT.
May be you could send the picture to my suppport,and we will check and reply you
Jeff
Will this work with an Explore Scientific ED102cf ?
Katherine Tsai
https://www.facebook.com/groups/ASIAIR/permalink/1457663907730161/
Hope this will help you.
David
Is EAF compatible with the Astrophysics 130mm f6.3 StarFire GTX “Gran Turismo” with 3.5″ Focuser (130GTX)?
ZWO.Moson
Sorry we haven’t test it before, you can refer to the “Support list” and “Mechanical diagram” in this website: https://astronomy-imaging-camera.com/product/zwo-eaf
John
Hi,
Does ASIAIR pro allow enough steps for eaf focuser to fully operate the range of the Celestron sct focuser?
sara.liu
maximum steps of ASIAIR PRO setting is 60000 steps.Thanks
Dan
I have one with a C9.25 XLT. With the f6.3 reducer onboard, I have to focus out all 60,000 steps, then using software resync the eaf back to 0 (I use INDI KSTARS, and this is just a couple of clicks on the INDI panel) then repeat 2 more ttimes. It actually needs 210,000 steps give or take to get to focus. Once you’ve done it once then it’s all fine, but the 60,000 non configurable limitation is a bit of a niggle. Would be better if I could set that myself in the software. Perhaps a limit of 300,000 steps would be better.
Support@ZWO
Thank you for the feedback.
