EAF Software Configuration
ASCOM Installation
The latest version of ASICAP has native support for the EAF. Other software packages will require the use of an ASCOM driver.
EAF ASCOM drivers can be found on the ZWO website:
https://astronomy-imaging-camera.com/software-drivers
ZWO ASCOM driver
Download and install support for EAF, then launch the EAF dashboard from within your astronomy software.
ZWO ASCOM driver-EAF
Introduction of ASCOM driver interface
ZWO_ASCOM_driver
Note: If you do not have EAF temperature sensor, you can use the inner temperature sensor to detect.
Connecting EAF to your Astronomy Software
There are many kinds of imaging software. We have listed the setting steps of EAF in the mainstream software, so that you can set the EAF in the software more quickly.
ASICAP
1.Open the focuser control panel.
ASICAMP_setting_12. choose the focuser that you connected.
ASICAMP_setting_23. Set suitable settings for your EAF.
ASICAMP_setting_3
ASIAIR
1. On the ASIAIR main screen find the icon for the EAF.
ASIAIR_EAF_setting_12. Click the icon and enter the EAF settings page.
ASIAIR_EAF_setting_23.EAF Advanced Settings.
ASIAIR_EAF_setting_3
Sharpcap
1.Open Sharpcap settings.
Sharpcap_EAF_setting_1
2.Choose ZWO focuser.
Sharpcap_EAF_setting_2
FireCapture
1.Open the focuser panel in settings menu.
FireCapture_EAF_setting_1
2.Check ”Use ASCOM Focuser”
FireCapture_EAF_setting_23. Choose ZWO Focuser in ASCOM panel.
FireCapture_EAF_setting_3
Sequence Generator Pro
SequenceGeneratorPro_EAF_setting
Maxim DL Pro
1. Open “Observatory panel”, in “Focuser 1” option, click “Choose…”.
MaximDLPro_EAF_setting-12. Choose ZWO Focuser in ASCOM panel.
MaximDLPro_EAF_setting-2
The SkyX
1.Open “Telescope” menu, and select “Telescope Setup”
SkyX_EAF_setting_1
2.Select “Focuser Setup”
SkyX_EAF_setting_23. select ASCOM Focuser
SkyX_EAF_setting_34. Setup the settings of ASCOM focuser.
SkyX_EAF_setting_4
5.Choose ZWO Focuser
SkyX_EAF_setting_5
Additional Installation Information
There is significant torque from the EAF stepper motor. We recommended setting the 0 position and the maximum number of steps as a first step to prevent possible damage to the focuser.
For the standard bracket installation:
The 0 position is recommended to be set to the position when the focuser is fully retracted.
The maximum number of steps is recommended to be set to a limit position less than or equal to the full focuser stroke.
For the curved saddle installation:
The 0 position is recommended to be set near the focus of the focus of the focus holder.
The maximum number of steps is recommended to be set to a limit position less than or equal to the focus seat stroke.
It has to be powered by 12V DC 0.5A and up.
20 Comments
  • johan coussens
    Posted August 17, 2020 at 7:24 pm
    hello,
    I hope all is fine with you. thanks for this great and nice hardware from ZWO
    please confirm : do i understand correctly that we can use more than 1 EAF unit from the ASICAP software? is it possible to choose the EAF unit for main scope and guide scope in the asicap software and to focus first guide scope and later main scope ?
    thank you for your appreciated reply.
    best regards
    johan
    • Post Author
      ZWO.Moson
      Posted August 18, 2020 at 12:13 pm
      Sorry the ASICAP can not control more than 1 EAF unit.
  • Mastria
    Posted October 25, 2020 at 7:59 pm
    Regarding to use of two EAF on same computer, I’ll have a configuration with two telescopes controlled by N.I.N.A. software with or without ASCOM. I know that I can use two N.I.N.A. instances at the same time, I can use one profile with 1st equipment e a second profile with another including telescope, cameras, guiding, focuser etc. Today I have one EAF for the first telescope and a Seletek focuser on another, its working ok, but I want to replace seletek with a second EAF. It’s possible work with two EAF on same computer without ID’s conflict, maybe with ASCOM? Thanks.
    • Post Author
      ZWO.Moson
      Posted October 26, 2020 at 5:42 am
      Sorry we haven’t use N.I.N.A, we don’t know whether it support.
  • Jim
    Posted November 18, 2020 at 4:40 am
    I am having trouble achieving full focus travel using ASIStudio.
    I have mounted the EAF to my Celestron c9.25 focuser using a bracket that directly connects the motor to the scope’s focus shaft (1:1 ratio).
    A c9.25’s focuser takes approximately 45 turns from fully in to fully out.
    I have determined that in ASIStudio, 10,000 steps equates to 1 full turn. This means I need to be able to set maximum steps in ASIStudio to a value of 450,000 steps. Unfortunately ASIStudio is limiting me to a maximum of 60,000.
    Please update your software/firmware to allow a higher limit or advise on how I should proceed.
    I suspect the same issue applies when using ASCOM.
    • sara.liu
      Posted November 18, 2020 at 9:34 am
      We will think about it.
      Please set the stroke near the focus or set the 0 position multiple.
    • Ash
      Posted November 28, 2020 at 7:32 pm
      Hi guys,
      I’m using the EAF on a RASA 8 with the SCT 8-9.25 bracket. Like Jim I cannot use the full travel of the focus knob. I have determined that it’s safely 28 turns from 0 to full travel on the focus knob and one full turn is roughly 5720 steps so the maximum “Max step” value would need to go up to 160,160 (5720 steps x 28 turns = 160,160) on a RASA 8. Please can you consider increasing the Max steps in a future update. Thanks
  • Yoshiaki
    Posted January 30, 2021 at 5:03 am
    I use EAF with MaxIm DL Pro 6.
    The ASCOM driver interface does not have a window for entering coefficients for temperature compensation.
    The MaxIm DL Pro side has a check button called “Temp. Tracking”, but is it not possible to perform temperature compensation operation with EAF?
    • Post Author
      Support@ZWO
      Posted February 2, 2021 at 10:34 am
      Option->Properties->Temp
      • Yoshiaki
        Posted February 5, 2021 at 9:18 am
        Hello
        > Option-> Properties-> Temp
        Is this the explanation in the ASCOM driver interface?
        If so, the letters “Option”, “Properties”, and “Temp” cannot be found in the ZWO EAF Setup window.
        Or is it the description in Observatory Setup in MaxIm DL?
        Please explain a little more so that I can understand.
        • Post Author
          Support@ZWO
          Posted February 5, 2021 at 9:52 am
          We have already replied to you in mail. Here is for quick answer. Please send mail if you have more questions.
  • victor
    Posted March 29, 2021 at 5:06 am
    It is available for iMac ?
    • Post Author
      Support@ZWO
      Posted March 29, 2021 at 9:10 am
      Yes, it is.
      • hbrooks2
        Posted January 3, 2025 at 6:19 am
        Where is the link? ZWO site seems to only have Windows version?
  • Jay DeShan
    Posted May 23, 2021 at 1:51 am
    I have 2 EAFs that control different telescopes very successfully, as long as only one EAF is plugged in at a time. I can not select, as I can with my different ZWO cameras. I don’t need them to run at the same time, but I would like choose either one depending on the telescope I want to use for the night, without changing cables. Am I not doing something correctly? Now matter how I try to select a different EAF, it always reverts to the same focuser.
    thanks
    • Post Author
      Support@ZWO
      Posted May 24, 2021 at 9:58 am
      You can set alias for EAF in Ascom.
  • Claudio
    Posted September 13, 2021 at 2:19 pm
    I have the ZWO-EAF-5V focuser and I feed it at 5VDC with the USB port.
    Can I power it at 12VDC?
    What is the maximum power limit in VDC?
    Thanks
    Clay
    • sara.liu
      Posted September 16, 2021 at 7:43 am
      No, you can’t.
      The power supply should be 5v.
  • Rob
    Posted September 13, 2025 at 2:28 pm
    Hi! Just curious… is there a complete management software like I see for Ascom for eaf that runs on Mac through the indi drivers?
Galaxy season is here
