How to Connect ASIAIR to Your SkyWatcher Mount?
Since its release in 2018, the ASIAIR has been very well received. One of the things people enjoy the most is the GOTO accuracy. As long as your equatorial mount is one of the many that is supported then you to will have simple and accurate GOTO.
As one of the most popular mount brand in the world, SkyWatcher mount is widely used with ASIAIR. But how to connect these 2 devices?
There are two ways to connect your SkyWatcher mount to the ASIAIR.
1. Connect via serial port.
Connect the RJ – RJ232 (supplied with the mount) to the hand controller and the RS232 – USB cable supplied with the ASIAIR. This method does not require the purchase of any extra cables. In the ASIAIR App select SynScan when choosing your mount.
ASIAIR_SkyWatcher_Mount_Connecting_1
The EQ8 and other newer mounts do not require an adapter but can instead be connect via the hand controller straight to the ASIAIR with the cable supplied with mount.
ASIAIR_SkyWatcher_Mount_Connecting_22. Connect via EQMOD.
If you prefer, you can connect from the SkyWatcher mount, straight into the ASIAIR, bypassing the hand controller. To use EQMOD, you need to purchase a third party, EQMOD dedicated cable. Another advantage to using EQMOD is you can skip the star alignment and go straight into plate solving.
ASIAIR_SkyWatcher_Mount_Connecting_3
In the ASIAIR App, select EQMOD when choosing your mount.
And how to connect SkyWatcher AZ-GTi Mount with ASIAIR?
The AZ-GTi is a great portable mount and works with the ASIAIR via not just EQMOD but also wireless EQMOD.
ASIAIR_SkyWatcher_Mount_Connecting_4
You can check the whole tutorial here for how to connect SkyWatcher AZ-GTi Mount with ASIAIR:
https://astronomy-imaging-camera.com/manuals/ASIAIR_Sky-Watcher_AZ-GTI.pdf
126 Comments
  • satoshi
    Posted November 23, 2019 at 8:02 am
    My mount is SkyWatcherEQ5 goto. I connedt EQ5 to ASIAIR via EQMOD.
    I tried to use SkySafari while connecting mount via EQOD, but I can’t.
    Please tell me How to use SkySafari while connenting mount via EQMOD.
    • Katherine Tsai
      Posted November 27, 2019 at 8:03 am
      Actually there is no need to connect SS when you use ASIAIR.
  • Khachik
    Posted January 24, 2020 at 9:43 pm
    Can ASIAIR work with AZ-GTi in alt-az mode (for plate solving only, not tracking) or it requires the equatorial wedge? Thanks!
  • R. Wong
    Posted February 12, 2020 at 8:43 am
    1. where can I buy the EQMOD cable for HEQ5 mount and skywatcher mount?
    2. I want to order the new version of ASIair pro
    3. where can i install the android version of ASIair app? what is the minimum spec. requirement?
    • Katherine Tsai
      Posted February 12, 2020 at 10:08 am
      1. You may check it online, like Amazon.
      2. It is expected to be available around March due to the coronavirus, we have to work at home and delay our delivery, but you can order it now.
      3. From Appstore and Play store, for more info, pleas click
      ASIAIR PRO
  • Bryan
    Posted March 25, 2020 at 1:03 am
    This looks like a very good solution.
    Am considering the ASIAIR PRO
    Can you confirm that this will control a Celestron CGEM mount?
    Thank-you,
    Bryan
    • Katherine Tsai
      Posted March 25, 2020 at 2:58 pm
      Yes, ASIAIR PRO supports Celestron CGEM mount.
  • Mike
    Posted April 2, 2020 at 4:53 am
    This thing is amazing. The new update that allows you to use your home network has been very welcome. I can now manage everything from indoors.
    Can’t wait for the asi air pro!
  • Abdul-Aziz
    Posted April 24, 2020 at 12:21 pm
    Can the ASiair Pro connect to the Sky-Watcher AZ GTI?
    • Post Author
      Moson
      Posted April 26, 2020 at 1:48 am
      Yes, the ASIAIR PRO can connect to the Sky-Watcher AZ GTI.
    • Tomasz
      Posted September 4, 2020 at 5:42 am
      Is anyone able to tell me how to conect asiair pro to NEQ6. -pro ??
      • Post Author
        ZWO.Moson
        Posted September 7, 2020 at 6:07 am
        We suggest you use EQ Mod cable, one end of the cable connect to ASIAIR PRO,and the other one end connect to your NEQ6 Pro.
  • Óscar
    Posted April 27, 2020 at 11:49 pm
    My equipment: Skywatcher MAK127 AZ GoTo
    Software used: SkySafari Pro
    What I want: wireless connection to mount and camera
    Is ASIAIR compatible? Which model?
    Differences between ASIAIR and SKYFI III?
    Thank you,
    • Post Author
      Moson
      Posted April 28, 2020 at 3:10 am
      Yes, the ASIAIR is compatible with your mount. You could use RJ-RS232 to USB-RS232 to connect your mount with ASIAIR. And then set IP Address (e.g 10.0.0.1) and Port Number (e.g 4030) in SkySafari. Now you could use ASIAIR APP in your phone to contral the mount.
      Maybe you could see the description on our website to see the differencs between ASIAIR and SKYFI III.
  • David
    Posted May 8, 2020 at 5:19 pm
    Will the Asiair Pro and suitable camera work with a Skywatcher Star adventurer and Skywatcher 72ed telescope, with a ZWO 30mm f4 guidescope?
    • Post Author
      Moson
      Posted May 9, 2020 at 1:28 am
      Yes, the ASIAIR PRO is support the Skywatcher Star adventurer and will work with Skywatcher 72ed telescope, with a ZWO 30mm f4 guidescope.
  • Jean Paul
    Posted May 9, 2020 at 1:13 pm
    Hello ZWO,
    Can I open an image on the ASIAIRpro, solve it, then goto the same position?
    This is to finish a previous imaging session,
    Thank you
    • Post Author
      Moson
      Posted May 11, 2020 at 3:59 am
      Sorry, the ASIAIR PRO does not have this feature.
  • davide
    Posted May 14, 2020 at 11:54 am
    ciao è possibile connettere asi air a Bresser exos2 goto?
    • Post Author
      Moson
      Posted May 15, 2020 at 1:49 am
      Sorry the ASIAIR PRO does not compatible with bresser exos 2 goto.
  • Marc
    Posted May 16, 2020 at 6:17 pm
    Hello,
    The asiair pro is a wonderful tool. However I cannor connect it to my 10micron 1000hps. Neither wifi nore the cable works. Could you help me? Thanks in advance.
    • Post Author
      Moson
      Posted May 18, 2020 at 7:14 am
      You could control the mount by connenting the net port on the ASIAIR PRO, then select ports 3490, 3492 in the software.
  • Jason Melenberg
    Posted June 13, 2020 at 2:39 pm
    The asiAir pro will not recognize that the st-4 cable is connected between my asi120mm-mini and the iOptron skyguider pro when I select “on-camera-st4” on the mount selection. It says “connect failed: please open the guide camera first”. The guide camera is already connected and able to loop photos.
    Do you know why it won’t recognize my mount? This works with other people’s setups. I based my setup from Peter Zelinka on YouTube and his doesn’t have that error message. I’ve tried iPhone iPad and android. Everything is on and the rest of the functions within the app work. If it doesn’t see my mount I’m afraid it won’t actually guide. Please help – I just spent a lot of money on this gear and this hiccough is rather frustrating.
    Thanks in advance!
    • Post Author
      Moson
      Posted June 15, 2020 at 3:35 am
      You could check the ST-4 cable whether it works fine and plugged tight. You could also try connect the guide camera to the ASIAIR Pro.
  • Gonzalo Sánchez
    Posted July 15, 2020 at 8:32 am
    Hello. I have the SW NEQ6 PRO. And after getting the ASIAIR PRO i have experienced the connection problem.
    My hand control diésel not have USB port. Online 2x RJ
    When trying the solutión you give (attached bellow ). i miss one cable. could you tell me wich is the cable for the Connection beetween handcontrol and the mount? And, how do you connect (RJ – RJ232) and the (RS232 – USB) since both are male?
    Given solución:
    • Katherine Tsai
      Posted July 16, 2020 at 8:52 am
      1. The cable is provided by mount, it is the cable connect the mount and controller.
      2. No, one is male and one is female so they can connect to each other and you can connect the mount hand controller to ASIAIR USB port.
  • Gonzalo
    Posted July 15, 2020 at 10:30 am
    Hello.
    I have a NEQ6 PRO and after getting the ASIAIR PRO i am experiencing connection problems.
    I have read the example of connection but i miss one cable on your advice . The One That goes from the synscan To the mount. What kind is it?
    I an facing another problem on It. Is the fact that both rs232 cables (the mount one and the asiair one) are male. And you say that there is not need to get any other cable for this connection.
    My Synscan model has not got the usb port.
    Here is your advice
    • Katherine Tsai
      Posted July 16, 2020 at 8:49 am
  • James Pavlock
    Posted July 15, 2020 at 10:04 pm
    These directions make little sense to me. I bought an EQ6-R last month. First the “original” cable that came with the mount and hand controller looks nothing like the diagram. It’s simply a phone jack on one end, plugged into the phone jack called “hand controller” on the mount. So I don’t see how one connects the ASIAir Pro with the cables under Scenario 1.
    Second, why connect through the hand controller at all? What benefit is there? If you get a ISB 2.0 A to B (not supplied by ZWO) you plug in one end into the mount’s port and the other into the ASIAir Pro unit.
    Simple. Why get complicated in these instructions?
    Second,
    • Katherine Tsai
      Posted July 16, 2020 at 8:24 am
      1. First, connect the hand controller to the mount, then connect the hand controller to ASIAIR USB port, you will need to convert the RJ port to USB port.
      2. If connected via EQmod, it is easier, we recommend our customer to use this method.
    • James Pavlock
      Posted July 16, 2020 at 11:21 pm
      This still makes no sense to me.
      I connected my NEW EQ6-R Pro Mount (which has a USB PORT) directly to the ASIAIR via a USB2 A -B cable. Since I have a USB port on the mount, I understand it DOESNT NEED an eqmod cable.
      Nonetheless, until I inputed through my hand controller (which I also had to connect to the mount) the intro date, time, long lat etc, I couldn’t seem to control the mount by the asiair. Is this correct? That I still need to use the hand controller initially?
      Do u have a complete tutorial on how to get started with ASIair?
      • Katherine Tsai
        Posted July 24, 2020 at 10:25 am
        Yes, you are connecting EQ6R PRO in the right way. It needs to input the date, time, long lat, etc initially.
      • Martin Groen
        Posted November 29, 2020 at 8:19 am
        Hey James
        Also have a new eq6-r Pro and ASIAIR Pro. I´m wondering if you`d be so kind to share the settings you use on the ASIAIR Pro when you connect to the mount. I can’t seem to get a connection via the USB A-B which was not included in the box. I’ve had issues with the camera setups but have overcome them, no thanks to the manuals from ZWO. this last hurdle however is beginning to make me a bit disappointed. When I try and search for connection options in the drop down menus there are no “usb to mount” options.
        Do you know af any good tutorial online for aid?
        Thanks. Hope you fixed your issues.
  • James Pavlock
    Posted July 16, 2020 at 11:45 pm
    I connected my EQ6R-r Pro mount to the asiair via usv2 cable.
    I still had to use the mount’s hand controller to do intro date, time, long, lat. why?
    So I used the hand controller to input this info and the asiair app is showing, in Telescope Settings, a value for RA of 20h 21m 20s, even though my mount is in its home position and the entire mount is pointed directly at Polaris. Dec is 00 00 00. Why is this? I haven’t polar aligned yet. Is this RA value an error?
  • David
    Posted July 21, 2020 at 8:12 am
    Hi, just purchased ASIair Pro. I’m using a Skywatcher EQ5 SynScan mount, Evoglide-59ED guidescope with a ZWO ASI Mini camera.
    Controlling the app thru an ipad
    I can’t get my telescope to communicate with the app for PA and plate solving. D I need to buy a special cable or maybe change the settings?
    One of the error messages I get is that I need to PA and 3 star align 1st? I thought that was one of the main advantages of this app?
    Please advise
    • Katherine Tsai
      Posted July 22, 2020 at 8:32 am
      Are you connecting ASIAIR and mount via hand controller? Please connect the hand controller to the mount first and then connect the hand controller to ASIAIR USB port via RS232 cable.
  • photon
    Posted August 11, 2020 at 8:01 am
    Can I use ASIair with Orion’s XT10g (Dobsonian, goto, alt-az) ? It has a synscan hand controller. It also supports WiFi. Thank you !
    • Post Author
      ZWO.Moson
      Posted August 13, 2020 at 4:00 am
      Sorry we don’t have test this mount. But you could try connect the synscan with ASIAIR via USB cable, and choose “Orion Atlas/HDX/Sirius” in the app drop-down menu options.
  • Jeanine
    Posted August 19, 2020 at 11:47 pm
    Equipment is Rasa 11, skywatcher EQ6-pro, ASI 294. I’m having a few problems.
    After polar aligning, the goto function doesn’t consistently take me to a requested target. How can this be consistent and The target centered?
    The photos are in black and white (not color). Is there a setting in ASIAIR pro to get photos in color and to accurately goto target each time?
    Also the photos are jpegs when transferred from thumb drive to the computer. Are raw files not available in ASIAIR pro?
    Thanks for your help.
    • Post Author
      ZWO.Moson
      Posted August 21, 2020 at 3:19 am
      1.Check the EQ6-pro has been balanced before polar aligning, and the mount is in zero position before connect the power. Check the “Tracking” has been opened. Also open the option “GoTo Auto-Center” and click the “Sync to Mount”.
      2.Close the “Mono bin”
      3.The photos taken by ASIAIR PRO are Fit files format. The ASIAIR PRO supports RAW files.
      There is the link for your reference:https://astronomy-imaging-camera.com/manuals/ASIAIR_PRO_User_Manual.pdf
  • Mark
    Posted August 24, 2020 at 3:32 pm
    I have an EQM-35 Pro and have not been able to connect in any manner other than ST4. I am able to connect my Canon Camera (5dsr) and guidescope (120mm-s). I was able to do a polar alignment, but I could not get the connection to the mount via any of the skywatcher synscan options. There is no USB connection option only a serial connection option or Ethernet. What is the point of having a newer mount if it can’t be recognized by the latest firmware I assume 5.81. It appears that you recommend purchasing an EQMOD cable. Does the SynScan still have to be connected to the mount for location and date adjustments? Does the EQMOD cable simply connect from the asiair to the mount’s autoguiding port, and do you have to disconnect the SynScan after inputting the information. Thanks.
    • Post Author
      ZWO.Moson
      Posted August 27, 2020 at 2:41 am
      1.Yes, you need an EQMOD cable. When you connect the mount and ASIAIR via EQMOD cable, you do not need adjust the location and date.
      2.The EQMOD cable directly connect from the ASIAIR to the mount’s handcontrol port.
      3.Do not need connect the SynScan.
      • jlmkeschmitz
        Posted December 11, 2021 at 8:23 pm
        Do you have a recommended EQMOD cable? I have a cable but I guess it’s not the correct cable.
        • Memory Ji
          Posted December 15, 2021 at 8:19 am
          You can search the EQMOD cable to connect PC, it also works to ASIAIR;-)
  • Alex
    Posted August 27, 2020 at 11:03 am
    I have a EQ3 mount and eqmod cable. I plugged the cable into the sync scan controller and the other end is asiair. In the asiair app, I selected [EQ MOD with sky safari] and baud is 9600, serial rs232. Unfortunately, I cannot connected
    Could you tell what has been wrong in this setup? Thanks
    • Post Author
      ZWO.Moson
      Posted August 31, 2020 at 2:17 am
      You can try select [EQMod Mount].
  • Georg Nyman
    Posted September 5, 2020 at 10:02 am
    Hello everyone, I would ask for help and information about the following: I use the NEQ6-R Pro with USB plug in, the ASI AIR, the ASI120M as my guiding camera and either the Nikon D810a or the ASI1600M plus EFW as imaging device. Focussing is done with the EAF.
    Now the questions: When I connect the ASIAIR with the handcontroller and set the scope to Skywatcher SynScan, it works fine as long as I do not start the guiding routine – then the mount starts to move away and calibration does not work (ST-4 cable connected from ASI120 to NEQ6). When I set the mount to ST-4 on camera, the mount does not move but guiding calibration and operation is very fine. So either I can control the mount or the guiding, not both.
    Next problem: When I use the ASI1600M plus EFW, the focus changes of course, when I switch from L to R oder Ha or whatever. I do not see any possiblilty to set a different focus position for the ASI EAF in the ASIAIR menu. Did I miss something? Focus must be adjusted because the image in L is sharp and with Ha or OIII ist blurred – not much, but it is definetly not in focus.
    Of course, when I use the NIkon D810a, that problem does not exist – only the fact, that there is no temperature compensation for the possible focus change when the temperature is dropping during the night.
    Well, are these the limitation of that tiny system? Then I have to live with it. But the inability to use guiding when the mount is set to Skywatcher SynScan should have a solution, I think. Maybe I connected something wrong.
    Can you please advise me?
    Thanks!
    • Post Author
      ZWO.Moson
      Posted September 7, 2020 at 6:58 am
      1.You do not need connect the ST-4 port to ASIAIR, you only need connect it via USB cable to ASIAIR. And then choose EQmod on the ASIAIR app.
      2.You did not miss something, we will add the auto focus function in the next version of ASIAIR. And it will release in the near future.
  • Antonio
    Posted September 6, 2020 at 8:15 pm
    Hi, I’ve read I need to use an EQMOD cable to connect my Skywatcher EQ3 mount to ASI AIR PRO.
    Is it possible to connect this Skywatcher Synscan EQ3 Mount using the wifi adapter?
    I followed the procedure written for AZ GTI wi-fi, but it doesn’t work.
    Regards, Antonio.
    • Post Author
      ZWO.Moson
      Posted September 8, 2020 at 3:20 am
      Sorry it can’t connect with WIFI adapter.
  • Joe S.
    Posted September 24, 2020 at 8:04 pm
    Hi,
    Does the ASIAir include the necessary FTDI drivers for the EQMod Cable to function? I have an EQMod cable I use with my HEQ5 but I had to install drivers on my laptop for the cable to work. Or is it that I just got a cheap cable (it was $4.99 but works great once the drivers were installed) that required the drivers separately? I ordered an ASIAir but want to make sure I don’t have issues with EQMod.
    Also, I’ve seen some using Bluestacks on a PC\Laptop with Windows to emulate iOS and run the ASIAir App and SkySafari. But I would assume there is still no way to tie it in with the Windows Based versions of Stellarium or Astrophotography tool? I have the Synscan Wifi adapter but saw in other post where the response was no go with ASIAir. It would be great if ASIAir could share the Synscan Wifi Adapter with a Laptop via the WiFi connection. Others would say it defeats the purpose but I love Stellarium but also the functionality of the ASIAir App.
    Thanks!
    • Post Author
      ZWO.Moson
      Posted September 27, 2020 at 2:21 am
      There is no any drivers required in using EQMod function.
      Yes, the ASIAIR can not be tied in with the Windows Based versions of Stellarium or Astrophotography tool.
      Sorry the ASIAIR PRO can not work with Synscan Wifi adapter, but we will convey your feedback to our des, and they will consider this.
  • John McDonnell
    Posted October 5, 2020 at 4:35 am
    Can I use the ASIStudio software to control my ASIAir. I do not want to have to buy a tablet just to use my ASIAir. My smart phone screen is too small to use for Astronomy stuff.
    • Post Author
      ZWO.Moson
      Posted October 9, 2020 at 3:09 am
      Sorry the ASIStudio can not control ASIAIR. Maybe you can use Android emulator in your computer.
  • Filipe
    Posted October 8, 2020 at 8:50 pm
    I have just bought an iOptron CEM70G. I have setup an old PC running Windows 10 2020 with the ASCOM Platform, IOptron Commander, iPolar, PDH2 and just need a clear night!
    I like the all in one ASIair approach though. A few questions
    1. Is the CEM70G supported and if so what is the best way to connect to it? The built in iPolar and iGuide cameras are accessible on the CEM70G main USB 3.0 port.
    2. Is the built in iPolar camera (basically a Windows HD camera (1280 x 960)) supported
    3. Same question for the iGuide
    Apart from that happy to use ZWO cameras on the Celestron Edge HD 8”
    Many Thanks
    Phil
    • Post Author
      ZWO.Moson
      Posted October 10, 2020 at 3:21 am
      Yes, the ASIAIR PRO support CEM70G. You can connect the mount to ASIAIR PRO via USB port, select CEM40 in the AIR app, baud 115200.
      But sorry to tell you that ASIAIR PRO does not support the build in iPolar or iGuide.
  • Ashley Powell
    Posted October 9, 2020 at 1:47 am
    Why are the instructions for using the ASIAir Pro with the NEW EQ6R-Pro so vague? You really need to create a step by step guide for such a critical item rather than having vague guides and conflicting answers.
    I have the mount connected to the Air via the mounts USB port. Do I need the hand controller? You seem to imply “yes” in some answers above. Why?
    I need to select “EQMod” as the mount “type” in the ASI App, is this correct?
    What is the correct connection, setup and startup process when using the EQ6R-Pro? (exactly)
    • Post Author
      ZWO.Moson
      Posted October 10, 2020 at 3:01 am
      Sorry for the inconvenience. We can’t create such a clearly guide due to the ASIAIR PRO supports a huge number of mounts.
      You do not need hand controller when connect the mount to the ASIAIR PRO via the USB port. And select “EQMod” in the ASIAIR app, baud 115200.
  • Matt
    Posted October 15, 2020 at 5:40 pm
    Hi
    I have a Sky-Watcher EQ-6 mount (with RS-232 connection) an I tried to use an EQdir cable (Ikarus tech.) with the ASIAIR and the mount wasn´t detected. Is there any driver problem?
    Thanks!
    • Post Author
      ZWO.Moson
      Posted October 16, 2020 at 2:26 am
      Try to use another EQdir cable.
  • Pascal Fumoleau
    Posted October 23, 2020 at 12:20 pm
    Bonjour
    Je n’arrive pas à connecter ma star adventurer avec l’asiair pro, comment dois je la raccorder
    Merci Pascal
  • davide
    Posted November 7, 2020 at 5:04 pm
    Asi Air è compatibile con Celestron SLT? grazie
    • sara.liu
      Posted November 11, 2020 at 6:39 am
      Hi,
      ASIAIR is compatibile with Celestron SLT;-)
  • Francesco
    Posted November 17, 2020 at 3:49 pm
    Hi, I have a problem with asi air pro.
    I currently use an eq5 pro mount, connected through the eqmod cable.
    Everything works well, I can solve without any problem, I center the object very precisely, but I never finish a session because the mount always makes the optics slam on the telescope tripod.
    I checked the date and coordinates and they are correct, I use the latest version of asiair pro. What am I doing wrong?
    Thanks in advance
    • sara.liu
      Posted November 18, 2020 at 9:05 am
      Enable the Auto Meridian Flip switch On under the Autorun Settings page.
  • Brian Walton
    Posted November 18, 2020 at 1:31 pm
    On ASIairV1.1 can I use it to connect to Skywatcher Synscan WIFI dongle on a Skywatcher EQ3Pro Synscan
    Naturally if I connect to the dongle WIFI through my IPad I couldn’t connect to the ASIair WIFI.
  • Walt
    Posted November 28, 2020 at 12:16 am
    I received a new EQ6-R Pro and ASIAIR Pro last week. I’m having trouble connecting them using a USB cable. I have tried setting EQMod Mount and 115200 baud in the ASI settings with my USB cable connected to the mount and also to the Synscan USB port but it will not recognize the mount. I did figure out that I can use Skywatcher Synscan with the USB cable connected to the Synscan controller after a start alignment. However, I would like to use the mount without the controller. What do I need to do to get the ASI app to recognize the EQ6 on EQMod Mount setting?
  • Ron Macaluso
    Posted December 9, 2020 at 6:56 pm
    I cannot get the pro to sync with the skywatcher heq5 I also cannot get the pro to go into station mode this is getting very frustrating I’ve tried the suggestions everybody is talked about on here but none of them seem to be working I have the EQMOD connected
    Thank you for any help
  • Robert
    Posted December 17, 2020 at 12:01 am
    Hi
    I’ve just received my ASIAIR pro.
    2 questions regarding connecting it properly with my sw eq6-pro mount
    1. I believe not all cables usb->rs232 are fine to use? From what I can see USB to RS232 COM FTDI FT232RL should work fine and connect?
    2. How do I connect guiding? Can see the todo anywhere. I use zwo asi 120mm mini. Do I need to use rj12 from my camera to mount? Or use usb to rj12 adapter so I connect usb to ASIAIR pro and rj12 to my guiding mount? Or I don’t connect anything and the connection from point 1 does the trick and enables the guiding? And I only select eqmod?
    • Post Author
      Support@ZWO
      Posted December 17, 2020 at 6:45 am
      1.Just 1 eqmod cable needed.
      2.Please use USB directly connect asi 120mm mini to ASIAIR pro and we recommend eqmod.
      • Robert
        Posted December 17, 2020 at 7:14 am
        I think I want to completely skip the HC and just don’t use it at all.
        So I’ve ordered a dedicated eq6 pro eqmod cable. Then I connect it to usb in ASIAIR and eqmod on my eq6. That’s it? It will then control both the mount and the guiding, just 1 cable needed in this case to control both?
        • Post Author
          Support@ZWO
          Posted December 18, 2020 at 2:48 am
          Yes, just 1 cable needed.
  • John holmes
    Posted January 7, 2021 at 1:19 pm
    Asiair pro will not connect to the skywatcher az gti
    I have gone through all the settings as advertised on you site
    Changing settings in SynScan and selecting eqmod mount
    Ethernet port 11880 udp slide to connect and always fails ?? Help anyone
  • Russell
    Posted January 11, 2021 at 3:00 am
    Comment *
  • Russell
    Posted January 11, 2021 at 3:19 am
    For anyone having issues with the EQ6-R PRO please look at the following link https://gist.github.com/timucingelici/217ac492bc2b127c6645ce033463d265
    I have had similar issues to many other connecting directly to my mount using the usb a to usb b cable, i have been able to update my hand controller firmware and my mount firmware but am unable to connect it to eqascom on the pc. I have also been unable to connect to the asi air pro using every setting possible.
    It appears the culprit is a new version of the prolific serial converter chipset that has been installed on the mount and is not yet supported by the asi air i also suspect my pc driver will not be up to date as well.
    The link above mentions a way around the issue but is a risky and complicated process. Until an update for the air fixes the issue people with the new chipset like myself will just have to buy an eqmod cable.
    For a deeper explanation from my understanding the usb port on the latest mount version has an inbuilt serial converter that automatically converts the high level instructions from your pc etc into low level ones for the motor control board. Therefore if its a new chipset thats not fully supported as yet the easiest fix is an eqmod cable as i understand it has its own converter built into the cable. This should only be on the latest versions of the mount supposedly.
    Feel free to correct me but thats what iv found after the last 5 days of searching
    • Post Author
      Support@ZWO
      Posted January 11, 2021 at 8:39 am
      Thanks for sharing this.
  • Angela
    Posted January 11, 2021 at 10:49 am
    Hello I have an HEQ 5 PRO and I am not able to connect properly with direct cable please advise as to how I can connect to ASIAIR PRO and or direct me to a detailed instruction on procedure as I have been researching for quite some time and it is very frustrating your help is greatly appreciated
    Angela
  • Theodor
    Posted January 26, 2021 at 8:56 am
    Is the AsiAir Pro compatible with the “FORNAX FM 52” Equatorial Mount?
    Cheers, Theo
  • Julien
    Posted February 18, 2021 at 8:08 pm
    Hello,
    I can’t connect my Asiair pro to my NEQ6 mount. I tried to connect it to the serial port of the mount (named “hand controller”). Then I choose the EqMOd mount (9600bauds) in the asiair app. The Serial is showed as “connected” but I get an error “connect failed …”.
    When I try to connect the asiair to the synscan (v3), I’ve got the same problem.
    Note: on the other hand, I can connect the Asiair pro with my ASI120 and AIS533 cameras.
    Do you have a solution ?
    • Post Author
      Support@ZWO
      Posted February 20, 2021 at 9:56 am
      Mount:HC Port -> “RJ” -> HC -> NEQ6 Cable(RJ-RS232 male -> USB-RS232 female)-> ASIAIR USB port
  • Mark Sellars
    Posted March 8, 2021 at 1:26 pm
    What is the maximum baud rate that I can use when connecting my ASIair Pro to my Skywatcher AZ-EQ6-GT mount using the EQMOD (USB A to RJ-45) cable? 9600? 115200?
  • GreggBellman
    Posted March 11, 2021 at 7:50 pm
    This is so disappointing…I can not connect to my EQ6-R Pro with ASIAir Pro. I have ordered the EQMOD cable but have tried connecting USB A to USB B on the hand controller. Still connection fails, says it’s connected but when I turn it on if fails to connect. I have a very popular mount and ASI cameras and ASI Air Pro seems very popular but still the documentation and support seems extremely poor. Maybe SkyWatcher and ASI could talk to each other and work this out, just saying! I sure wish I had read this thread prior to my purchase.
    Wouldn’t it be some much better to just include the EQMOD cable with the device, really how many power cables do I need? The vast majority of this whole thread addresses this one problem which could be solved with one cable! I’ll pay more to get all the cables I need, including power supply! Really…NO POWER SUPPLY!
    This is not a confidence builder, maybe NINA or SharpCap are better solutions with the added benefit of using any camera I want! Why would I buy a $5000 camera from a company that can’t handle the small stuff!
    Shaking my head!
    GB
    • Post Author
      Support@ZWO
      Posted March 12, 2021 at 8:21 am
      There is no need to use hand controller when using EQMOD.
  • Roger Coldiron
    Posted April 28, 2021 at 5:36 pm
    I’m having a new problem with communication between my ASI AIR PRO and mount. I’m using the PRO connected to the hand controller jack on my EQM-35 PRO. Everything worked extremely well for a couple of months but while shooting the last three or four nights, the AIR seems to stop communicating with the mount. I’ve changed the EQMOD cable and I’ve even reinstalled the AIR operating system. I can shoot a couple of rounds of photographs of one object but when I try to get the mount to slew to a new target, the slew screen pops up but nothing happens. It won’t even go to home position. The only way to get the mount to move is to turn the AIR off, then back on, manually move the mount to home position, the turn everything back on. Quite frustrating.
    Any ideas?
    Thanks,
    • Post Author
      Support@ZWO
      Posted April 29, 2021 at 8:28 am
      Please submit the log in APP feedback when the issue occur before turn the AIR off.
  • Marbach Stefan
    Posted May 14, 2021 at 3:56 pm
    Is it possible, to connect the ASIAIR to a Gemini Pulsar 2 Controller? If yes, wich cable and ports do I use and what is the setup (IP Adress, Port number, and so on)
  • Walter
    Posted May 22, 2021 at 3:24 am
    Hello again,
    the ASIAIR (not pro) is compatible with Onstep and Arduino? I´ve EQ3 mount dual axis with nano arduino and use the Stellarium or Cart du Ciel to move the telescope with ST4 port.. Thank you.
    • sara.liu
      Posted June 16, 2021 at 10:11 am
      The ASIAIR is compatible with the Onstep, but not sure of the Arduino.
  • Tom
    Posted June 3, 2021 at 8:03 pm
    I am sorry, it’s a DISASTER.
    Given how popular the SW EQ6 mount is i can’t understand how is it possible that is put several hundred bucks into both the ASIAIR and the mount and THEY DO NOT WORK together.
    OK, i can wait a few weeks… but it’s been HALF A YEAR. Seriously, any app in my phone gets updated faster. So why do i have to order cables, browse forums and keep waiting… i thought the “U” in “USB” stands for “universal”??
  • LT
    Posted July 4, 2021 at 5:45 pm
    Hello,
    I have the older EQ6 PRO running synscan V4.
    purchasing a ASI air Pro, and 2 cameras, I wish to skip the hand controller….
    I purchased a EQMOD cable, but am uncertain it has the right connections on it.
    i looked at
    https://astronomy-imaging-camera.com/wp-content/uploads/17.png
    but if I use the cables provided by ZWO ASI air pro box, it can no longer be connected to the mount.
    complete setup help required, as the connections aren’t lining up as your diagrams indicate.
    and forum posts are not illumating my problem.
    • sara.liu
      Posted July 8, 2021 at 7:38 am
      Please contact the mount with the ASIAIR Pro USB port directly by using the EQMOD cable.
  • Rolf Weber
    Posted July 7, 2021 at 5:05 pm
    Hello support team
    Is Bresser Exos 2 mount meanwhile also possible to be connected to asiair (not pro version) ?
    I read in another forum that it is supported now
    Is this true?
    Thank you in advance
    Best regards
    Rolf
    • sara.liu
      Posted July 8, 2021 at 8:02 am
      The ASIAIR is not compatible with Bresser Exos 2 mount.
  • Javier
    Posted July 18, 2021 at 1:35 pm
    I don’t know if it is a bug but if you are using the first methof, conecting serial port, and you are getting problems, first of all I would recommend to play with the baud rate.
    In my case some times works fine al 9600 bauds and others with 11500, and if one works, the other don’t.
    I’m using asiair with an Skywatcher eq8.
    Cheers
    • sara.liu
      Posted July 21, 2021 at 10:07 am
      9600 or 115200 depends on the mount protocol,please refer to mount manual.
  • Andrew
    Posted July 19, 2021 at 9:58 am
    Hi, Is the Saxon HEQ5 Pro mount supported? I tried to connect and it said mount not identified. I connected with a USB A – USB B male-male from the ASIAIR Pro to the hand controller ( I don’t have an RJ-RS232 cable). The hand controller was connected to the mount. I selected ‘Skywatcher Synscan’ from the drop down menu for the mount. Is this the right selection for a Saxon HEQ5 Mount using Synscan?
    If not, will eqmod direct from asiair to the hand controller port on my mount work? Thanks.
    • sara.liu
      Posted July 21, 2021 at 10:09 am
      Skywatcher synscan needs the star Align,you can refer to the tips in ASIAIR app, recommend the EQMOD.
  • MarkD
    Posted July 28, 2021 at 5:06 pm
    My equipment, AZ-EQ5 Pro Skywatcher mount, Nikon D750, Skywatcher Quattro 200P, ASIAir Pro, When I use the EqMod Cable (option 3), I cannot control the time on the AZ-EQ Mount, so when i go to an object it seems to be an hour off and does not line up with the selected object. It is greyed out in the app and cannot be adjusted in the app,
    So in order to set the time, I went back to option 1 and try to keep the Skysafari in the loop so I can set the time with Skysafari, but when I connect to the mount using the ASIair App, using the Skywatcher synscan option, i get a Connection Failed message “Polar and 3 star aligned required and please update the HC FW to the newest version…..”
    My preference is to use the EQMod Cable option. What workarounds are there for getting the time correct on the mount.
    • sara.liu
      Posted July 29, 2021 at 9:17 am
      It is possible to use the EQMod cable option.
      Please check the Time Zone and time option, then sync to mount to get the correct time; )
  • David Benjamin
    Posted August 3, 2021 at 3:19 pm
    How can I connect the star adventurer 2i WiFi mount to asiairpro?
  • Mauget
    Posted September 14, 2021 at 2:24 pm
    Bonjour ; j’aimerai avoir le schéma de branchement pour le boîtier Asiair (blanc et rouge, pas le pro )
    Pour connecter le SynScan goto dobson 203/1200 skywatcher; via la raquette ou directement sur moteur altitude ;
    Connecteurs disponibles sur la raquette ( version 04 39 19) carré (usb ) et rj 12 6 broches;
    Merci par avance
  • John Mazur
    Posted September 24, 2021 at 2:09 am
    Hi,
    I am trying to connect using method 1 and am not succeeding.
    The mount I am using is a SkyWatcher AZ-EQ5 GT.
    I know the cable works because I was able to update the SynScan Hand Controller.
    However, no matter which USB port I use on the ASIAIR I am unable to connect, getting the error:
    Can’t Connect. Polar and 3-Stars align required and please update the HC FW to the newest version, or check the connection of the USB cable.
    The telescope I have selected is: SkyWatcher SynScan.
    Thanks.
    • sara.liu
      Posted September 26, 2021 at 7:38 am
      If your cable has nothing wrong, can connect to the PC,
      please submit the log in the ASIAIR app.
  • HRISTO
    Posted October 13, 2021 at 11:33 am
    Hi there! I have the SW EQ6-R Pro, which has the USB-A port.
    1. I tried connecting the ASIAIR PRO with a USB A-B cable, but I got en error that there is no device connected to the serial port (or smth like this, I don´t remember the exact words). I saw a video tutorial with this type of connection and it worked (the guy just selected EQ Mod mount with 115200 baud). What could be the problem with my rig?
    2. Should I try the EQ mod cable? And is the USB-to-RJ45A cable safe for the mount? I read something about the voltage and how it could damage the mount if connected directly to a USB port… (not sure about this, but wanted to make sure)
    Thanks a lot!
  • Patrick Chiamberlando
    Posted December 6, 2021 at 6:23 pm
    Buonasera.
    Io posseggo un asiair prima versione e una montatura skywatcher eq 5, collegandoli con il cavo eqmode funzionava tutto bene.
    Non ho potuto usare il mio setup per 3 mesi ed ora che ho ripreso in mano il tutto non riesco più a seguire le stelle, escono dall’inquadratura. se mi ricordo bene dovevo scegliere nel menu della montatura eq mode e baud 115200, ora mi permette solo baud 9300. Dove sbaglio?
    Ho provato anche con un asiair pro di un mio amico ma ho lo stesso problema.
    Attendo risposta
    Grazie
    • Memory Ji
      Posted December 15, 2021 at 11:52 am
      Please send the log to us by ASIAIR App.
  • AJRobles
    Posted December 11, 2021 at 5:06 pm
    My mount is EQ8 and I have Asiair Pro
    The only way to use Asiair is conecting from the Asiair to the mount instead me keyboard
    Before this mount, I had one CGEM DX and no problem to conect the Asiair to the mount
    Now I dont know what can I do
    I tryed different ways, and different settings but I cant
    There are no manuals…
    Any sugestion? can you help me, please?
    Thanks
    • Memory Ji
      Posted December 15, 2021 at 8:40 am
      The mount can be connected directly by EQMOD cable.
