How to connect your mount to a computer? It’s easy with the ASIAIR!
As we are sure you are aware, there are lots of different brands of mounts out there, each with different ways of connecting to a computer. This has caused a lot of confusion with needing different cables, adapters and software to run mounts.
asiair vs other device
However, ZWO have the perfect solution, the ASIAIR. Compatible with the four major methods of connecting mounts to a computer (serial port, EQMOD, WIFI and USB).
1. Serial port connection method
asiair-mount-1
CEM25P/EC, ZEQ25, iEQ30, iEQ45, etc. When using serial port connection, two data cables are required to connect ASIAIR and equatorial mount hand controller (as shown above). Select the corresponding equatorial mount model in ASIAIR’s equatorial setup with a baud rate of 9600.
Note: ZEQ25 must stay on the menu page and accept the command connection successfully. After entering the menu, it cannot receive the control command from the serial port.
asiair-mount-2
Mounts like the CEM60 also uses two serial port cables, shown above. The difference between this mount and the previous is that you can bypass the hand controller and instead plug directly into the mount.
In the ASIAIR setup, select CEM60 in the equatorial mount model selection screen and set the baud rate to 9600.
2. EQMOD connection method
asiair-mount-3
EQMOD has some advantages over the previous examples, being that you only need one cable and no hand controller.
Simply select EQMOD in the ASIAIR setup screen. You can straight away use the mount without even doing a 1-star alignment.
3. WiFi connection method
asiair-mount-4
To use a wifi connection you must first set the WiFi parameters in the SynScan App. After this you can connect the mount the ASIAIR’s WiFi and select the static IP address, 10.0.0.11.
In the ASIAIR setup, again you select EQMOD protocol and connect via port 11880 UDP.
4. USB connection method
asiair-mount-5
Similar to the EQMOD, this method only requires one cable and no hand controller.
In the ASIAIR setup screen, you select the mount model and then the baud rate which for the CEM120 is 9600 and the CEM40 is 115200.
87 Comments
  • Erik Mardiste
    Posted October 17, 2019 at 10:48 am
    Hi guys just wondering about the skywatcher star adventure, if you can use it on that mount
    • ZWO ASI Camera
      Posted November 12, 2019 at 10:37 am
      Yes, the asiair could work with the skywatcher star adventure
  • Tai
    Posted October 18, 2019 at 12:47 am
    Hi Team
    Could you please tell me which Vixn mount can work great with your Asiair
    Also, if not yet, which brand mount has Wifi works with Asiar?
    Thanks
    Tai
  • Alfred
    Posted October 24, 2019 at 9:43 am
    Hi team,
    I have two japanese old mounts which is Sky Memo R with additional autoguider and a modified Takahashi PD4XY -B control box which are set out as below:
    https://page.auctions.yahoo.co.jp/jp/auction/o345084960
    https://page.auctions.yahoo.co.jp/jp/auction/x648748992
    May i know how should I connect to them and the setup in the App?
    Thanks.
    Alfred
    • Katherine Tsai
      Posted November 14, 2019 at 10:34 am
      These two mounts are two old and may not supported, you may try LX200 in the App.
  • Emre
    Posted February 18, 2020 at 9:22 pm
    Hello ZWO Team!
    I wonder if ASIAIR Pro would be capable with Celestron stock Alt-Az mount. I converted it to EQ mount by using a wedge.
    Thanks!
  • Julia V.M.
    Posted April 25, 2020 at 9:21 am
    Hi guys
    just wondering about the AVX Celestron?
    Could you please tell me which AVX mount can work great with your Asiair?
    thank you so much
    Julia
    • Post Author
      Moson
      Posted April 26, 2020 at 3:52 am
      The ASIAIR PRO can connect with Celestron Advanced VX mount.
      • Dave
        Posted May 28, 2021 at 11:32 pm
        That’s great news. I’ve tried connecting USB 2 to the HC as well as RS232 to an auxilliary port. Neither worked. So how do you recommend connecting ASIAIR PRO to an AVX?
        • Post Author
          Support@ZWO
          Posted May 31, 2021 at 9:16 am
          Mount->Nexstar hand controller USB mini B port-> ASIAIR USB port.
          Choose serial port, baud rate 9600.
          • Peter
            Posted September 8, 2021 at 5:41 pm
            I’ve been trying this setup without any luck. ASIAIR is not recognizing my brand new AVX mount at all.
          • sara.liu
            Posted September 9, 2021 at 9:44 am
            The AVX is supported, please refer to the prompt in ASIAIR telescope settings.
  • davide
    Posted May 14, 2020 at 11:56 am
    asi air è compatibility is bresser exos 2 goto? thanks
    • Post Author
      Moson
      Posted May 15, 2020 at 1:47 am
      Sorry the ASIAIR PRO does not compatible with bresser exos 2 goto.
  • Allen
    Posted June 4, 2020 at 12:05 am
    Will the asi air pro work with a Meade LX200GPS mounted on a wedge?
  • Sid
    Posted June 7, 2020 at 7:56 pm
    Can you provide recommended connection diagram for ASIAIR PRO, Celestron CGEM mount, 120mm guide scope, 294 Camera, SkySafari pro, powered hub, Wi-Fi connection. Wi-Fi extender?
    • Post Author
      Moson
      Posted June 8, 2020 at 3:37 am
      Sorry we can’t provide such a clearly connection diagram. Because the ASIAIR PRO can support large amount mounts and has varies of connection method.
    • Bob Miller
      Posted June 24, 2020 at 12:02 am
      Can I use my new iPad running IOS software> It only has one port.
      • Katherine Tsai
        Posted July 6, 2020 at 11:03 am
        Yes, you can. You do not need any port to connect ASIAIR PRO, it is connected via WiFi.
  • photon
    Posted August 11, 2020 at 7:14 am
    Does ASIair work with Orion’s Dobsonian goto mount (e.g. XT10G’s AltAz)? Thank you
    • Post Author
      ZWO.Moson
      Posted August 13, 2020 at 3:22 am
      Sorry the ASIAIR does not wrok with XT10G’s AltAz.
  • Dave Bender
    Posted August 22, 2020 at 1:39 pm
    Does the asiair pro work with a Meade lx200 acf 12”?
    • Post Author
      ZWO.Moson
      Posted August 24, 2020 at 3:35 am
      Yes, the ASIAIR PRO supports Meade LX200 ACF.
      • Jeff
        Posted December 10, 2020 at 4:58 am
        How do you cable connect the ASIAIR PRO to the Meade LX200 8″ ACF?
        • Post Author
          Support@ZWO
          Posted December 10, 2020 at 7:15 am
          1. You can go to Meade Website to find some info
          2. supported-mount-connect for your reference
          • Jeff
            Posted December 19, 2020 at 5:04 am
            I think you misunderstood. The meade site doesn’t know about the ASIAIR. How do I physically cable connect to the LX200 ACF? And how do I cable connect the autoguider? The AutoStar II hand controller does not have any additional ports.
          • Post Author
            Support@ZWO
            Posted December 21, 2020 at 6:38 am
            Sorry, we haven’t received feedback from users regarding how to connect LX200 ACF. If you find out the method and send to us, we would appreciate it.
  • Lisa Bromfield
    Posted September 7, 2020 at 6:04 am
    Is the ASIAIR compatible with a QHY guide camera?
    • Post Author
      ZWO.Moson
      Posted September 8, 2020 at 3:13 am
      Sorry the ASIAIR can not support the third part camera.
  • David
    Posted September 23, 2020 at 9:09 pm
    What is the simplest way to connect an Ioptron IEQ30pro to ASIAIR?
    Thanks
    • Post Author
      ZWO.Moson
      Posted September 24, 2020 at 2:56 am
      You can use RJ-RS232 cable which is the most simplest way.
      • David
        Posted September 24, 2020 at 5:37 pm
        Thank you for your quick response. I am also having a problem with the 120mm mini guide scope. No matter what I try I cannot get the ASIAIR PRO to recognize the camera.
        • Post Author
          ZWO.Moson
          Posted September 27, 2020 at 2:06 am
          Try different cables, USB ports, and test the camera in ASIStudio. If it still can not work, you can send an image to our support@zwoptical.com
  • Krister
    Posted September 27, 2020 at 4:01 pm
    Hi – Is there any documentation available to explain how to connect the ASIAIR to a Celestron Nexstar Evolution Alt Az mount WiFi module? Is it supported or do we need another cable to replace the USB/serial cable that won’t work on Celestron scopes? Any help would be appreciated…so far, doesn’t look possible. Thanks.
    • Post Author
      ZWO.Moson
      Posted September 28, 2020 at 1:48 am
      1. Mount->Nexstar hand controller USB mini B port-> ASIAIR USB port.
      2. You can also connect via RJ-RS232 -> USB-RS232.
  • Krister
    Posted September 27, 2020 at 4:06 pm
    Hi – although I understood both ASIAIR and Celestron StarSense are ASCOM compatible, it’s seems StarSense camera is not supported in ASIAIR guide scopes. Is this correct or is there any way to connect the 2? Thanks
    • Post Author
      ZWO.Moson
      Posted September 28, 2020 at 1:55 am
      Yes, the ASIAIR does not compatible with Celestron StarSense camera.
  • ADRIANA LUJAN AMEZ
    Posted September 29, 2020 at 8:07 pm
    Hi!
    I have the Meade LX70 mount and powered it with the SkyWatcher EQ5 GoTo kit.
    I want to know if this set is compatible with AsiAir Pro and how to connect it.
    Thank you very much!
    • Post Author
      ZWO.Moson
      Posted September 30, 2020 at 3:46 am
      Sorry the ASIAIR PRO can not compatible with Meade LX70 mount.
  • Brent
    Posted October 10, 2020 at 2:18 am
    I’m following option 1 to connect to an iEQ45 with the 8407+ hand controller and selecting iOptron iEQ30/45 & 8407 but no matter what baud I choose it can’t connect. Any advice?
    • Post Author
      ZWO.Moson
      Posted October 10, 2020 at 3:52 am
      Try to use different RS232 cable, and select 8406.
      • Brent
        Posted October 12, 2020 at 5:24 pm
        Thank you. I didn’t have another rs232 cable but was able to connect in a deferent way. I used a serial to USB adapter and plugged this directly into the mount and connected directly to the ASIair pro. With the ioptron hand controller connected to the mount I was able to connect the mount in the app. Preliminary tests seem promising. It did inexplicably disconnect a couple time but I was able to reconnect and was able to slew, goto and guide. Is there any downside in connecting this way?
        • Post Author
          ZWO.Moson
          Posted October 13, 2020 at 1:50 am
          Sorry we haven’t test this, so we do not know if there is any downside in connecting this way.
  • GEORGE
    Posted November 6, 2020 at 11:55 pm
    My imaging camera is a DSLR. My guide is an ASI120MC-S. My mount is a Skywatcher Synscan.
    I tried to connect via the usb/serial cable and I can connect and see all my devices. However the second I attempt to guide, my longitude gets flipped from W to E and everything goes the wrong way. I upgraded the HC and the ASIAIR V1 to latest firmware. No help. This longitude flip is all over the internet.
    Today I ordered an EQMOD cable. The HC wont be there. How do I then align the scope? I dont think plate solving works for a DSLR as the imaging camera. I have a second ZWO camera a ASI224MC. How can I align the mount?
    • sara.liu
      Posted November 10, 2020 at 9:57 am
      EQMOD follows the app prompt to ensure power on at position 0.
      If the DSLR can be analyzed when shooting in the preview interface, PA can be done. After PA is finished, there is no need to do scope align.
      If you have 224 camera, you can also connect 224 camera to the main camera and do the second step above.
  • Jeramygonzales23
    Posted December 14, 2020 at 9:21 pm
    Hi how do I connect my CGX-L mount to my ASiair pro?
    • Post Author
      Support@ZWO
      Posted December 15, 2020 at 3:20 am
  • Richard
    Posted December 19, 2020 at 7:16 am
    So I have not been able to connect my ASIAIR pro to my EQ6-r pro through Eqmod USB port nor the hand controller. I check the ports and they both work on their own but they just will not talk to each other. Everything else works fine except connecting to the mount. Any ideas? Already did the star alignment as well.
    • Post Author
      Support@ZWO
      Posted December 21, 2020 at 7:17 am
      EQ6-r pro choose serial port, baud rate 115200, and when using EQmod no need to do the alignment.
      • Netsyphon
        Posted December 23, 2020 at 1:13 am
        I am also unable to connect the mount and I am using 115200 baud. Instantly not detected.
        • Post Author
          Support@ZWO
          Posted December 23, 2020 at 3:16 am
          Did you choose EQMode Mount as Telescope in “Telescope Settings”?
  • Andrew Usher
    Posted December 20, 2020 at 6:13 pm
    Hi, I tried to connect my AsiAir to the Ioptron cem120 mount. Entered the correct mount cem120, the correct baud rate 9600 came up. But the Asiair refused to connect. After trying different leads and the different ways suggested to connect I still had no luck.
    But for some reason I decided to enter the mount as cem70 , the baud rate of 115200 came up. But this seems to work. Is this correct?
    Thanks for your attention.
    • Post Author
      Support@ZWO
      Posted December 21, 2020 at 7:55 am
      If this seems to work, it is correct.
  • Tim
    Posted December 27, 2020 at 3:16 am
    Trying to connect the ASIair Pro to iOpton ZEQ25GT with the Serial port connection method. I get connection failed every time. I have selected proper mount with 9600 Baud
    • Post Author
      Support@ZWO
      Posted December 28, 2020 at 9:31 am
      Do you use HC to connect?
  • Ian Fisher
    Posted January 17, 2021 at 3:55 pm
    Hi Zwo team, can you advise me on the procedure to connect asiair pro to AVX with sky portal wifi adaptor. Thanks
    • Post Author
      Support@ZWO
      Posted January 18, 2021 at 10:03 am
  • Frank Mraz
    Posted January 18, 2021 at 1:13 am
    Celestron CGX-L, ASIair Pro and EQMOD
    Is this combination a workable system ???
    • Post Author
      Support@ZWO
      Posted January 18, 2021 at 10:11 am
      3.If you want EQMOD, please use SkyWatcher.
  • Angus
    Posted January 20, 2021 at 10:27 am
    Hi, I’m trying to connect ASIAIR Pro to Skywatcher EQ6-R mount over WiFi using the SynScan WiFi dongle. Is this possible?
    I’ve enabled station mode on the SynScan dongle with SSID “ASIAIR_Dev.Fei”. I have the ASIAIR set to station mode & am trying to connect to the mount using “EQMod Mount” on IP 10.0.0.11 & Port 11880 UDP.
    Thanks for any help.
    • Post Author
      Support@ZWO
      Posted January 21, 2021 at 9:26 am
      Please make sure SynScan can identify EQ6-R first and then try the station.
  • Paolo
    Posted February 18, 2021 at 11:35 pm
    Hi there, I have a Ioptron Zeq 25 GT and I didn’t understand how to proper connect the mount to the Asi Air Pro. Is the Serial port connection method the only way to connect them ? The EQ Mod connection cable isn’t possible to exploite? Thanks
    • Post Author
      Support@ZWO
      Posted February 20, 2021 at 10:00 am
      Mount->HC->ASIAIR, baud rate is 9600.
  • Neill
    Posted February 25, 2021 at 12:14 pm
    Hi. I’m trying to connect my ASIAir Pro to my SkyWatcher 300P Dobsonian via the SynScan handset. I’m using the supplied USB to Serial adapter and serial cable to the V5 SynScan handset. I select Synscan from the list, but no matter what baud rate I try it will not connect. I tried the SynScan Beta as well, but that does not work either. What am I doing wrong please?
    • Post Author
      Support@ZWO
      Posted February 26, 2021 at 7:45 am
      Please contact support@zwoptical.com and we will send you instruction.
      • Neill
        Posted February 26, 2021 at 1:42 pm
        Thank you I will email. It works with an older V3 handset, so it is something to do with the V5.
  • Brian Walton
    Posted March 10, 2021 at 1:10 pm
    Trying to connect CEM 26 (not EC) to ASIair v1.
    hi sorry it’s not happening. I,ve got the WIFI station mode to be HBX as shown, the ASI air hotspot,2.4G , WIFI station mode HBX.
    Then however it’s Ethernet,IP 10.0.x.x port 4030 ,TCP
    Don’t want to put up address in ?
    But comes up connection failed.
    It’s the CEM 26. Not the CEM 26 ec. Don’t know if that matters.
    • Post Author
      Support@ZWO
      Posted March 11, 2021 at 6:01 am
      CEM26 mount wifi has not been tested yet, so appreciated for your update on it,thanks in advance.
  • TimJ
    Posted April 28, 2021 at 7:44 pm
    Which EXACT cable do I need to connect a D7200 Nikon DSLR to the ASIAir Pro. I plan in the future months to move over to my ASI 2600 CMOS camera. However, for now, I need to use my Nikon D7200. But I need the correct cable for that camera to plus into the port on the Air Pro. Please help.
    Tim J
    • Post Author
      Support@ZWO
      Posted April 29, 2021 at 8:40 am
      D7200 is not in the support list but one of our customer said in ZWO forum that D7200 works perfectly, when connected to ASIAIR pro via USB.
  • TimJ
    Posted April 28, 2021 at 8:21 pm
    What cable do I use to connect a Nikon D7200 DSLR on a Paramount MX mount to an ASI Air Pro?
  • Brian
    Posted May 30, 2021 at 5:55 pm
    Hi, I can’t get my ASIAIR Pro to connect to iOptron CEM40 via USB. 2 options for this mount appear in the drop down:-
    iOptronCEM40/GEM45 HC-FW 210101+
    iOptron CEM40/GEM45 HC-FW old
    I’ve also tried all the other iOptron mount options, nothing connects.
    Thanks, Brian
    • Post Author
      Support@ZWO
      Posted May 31, 2021 at 9:28 am
      CEM40–USB cable–ASI Cooled Camera USB Hub/A external USB Hub–ASIAIR USB port.
      It’s an iOptron Chip issue with the ASIAIR driver.
  • Kjell-Arne
    Posted June 9, 2021 at 7:20 pm
    Hi.
    Has anyone got the eqm 35 pro to work with aisair pro with usb connection to the controller itself, have I made it work once in about 40 attempts or do you have to use eqmode cable grateful for the answer thank you
    • Post Author
      Support@ZWO
      Posted June 10, 2021 at 8:03 am
      You can use either eqmod or Synscan.
  • Shyuan
    Posted October 12, 2021 at 1:20 am
    Hi, yesterday I tried to connect ASIAIR Pro to my mount (Sky Watcher AZ-GTi) via an EQMOD cable but failed. The baud rate was set to 9600 (in fact, I tried all values). Could you suggest me what to do next? I also tried changing the order of powering-on of the mount and ASIAIR Pro. I also tried using Sky Watcher’s Sync Scan APP to set AZ-GTi to EQ mode first before making a connection in ASIAIR APP (turning on the button in the Telescope setting)
    • sara.liu
      Posted October 22, 2021 at 9:10 am
      Please connect the EQMOD cable to the PC, check whether it works well.
      Please make sure the network is 2.4G when using the Sync Scan.
      After trying the two method, if it still does not work.
      Please contact support@zwoptical.com directly.
  • Doug
    Posted October 23, 2021 at 12:51 am
    Does the AsiAir Pro support Skywatcher Adventure 2i and Canon EOS T3 / 1100D connected via mini-USB to the Pro?
    Can the Canon Camera then be used to confirm manual Polar Alignment?
    After this is connected and setup, can the AsiPro can then slew the Skywatcher tracker and perform all your advertised features such as plating and stacking?
  • Yvan
    Posted November 25, 2021 at 11:56 am
    Bonjour
    J ai une eqm35
    Je n’ai que le câble usb2 comme moyen de connections avec l’asir plus.
    Sur l’application, cette connection entre l’asi air et la monture par le câble usb2 est pris en compte puisque c’est marqué ”connecté ”
    Mais impossible de se connecter.
    J’ignore quel configuration choisir, eqmount ? Skywatcher synscan ? Synscan?
    J’ignore aussi quel valeur baud mettre?
    • Memory Ji
      Posted December 15, 2021 at 12:03 pm
      Please try to connecte handle and select the EQMod driver in ASIAIR App or use extra EQMOD cable;-)
