[ASIAIR GUIDE] Four ways to connect the ASIAIR PRO to network (UPDATED)
This tutorial teaches you how to connect the ASIAIR PRO to network, or how to connect the ASIAIR PRO box to the ASIAIR APP. They mean the same as ASIAIR PRO is controlled by the ASIAIR APP on your phone or tablet via network.
What is ASIAIR?
2
ASIAIR is an intelligent astronomy control system linked by Wi-Fi, which includes both hardware and software. Hardware is the well-known small box, software is the ASIAIR app, to remote control the astronomy camera, equatorial mounts, and many other related devices to take astrophotography.
ASIAIR App supports both iOS and Android platforms, running on smartphones, tablets, etc. We will call it ‘App’in the following text.
We will demonstrate 4 methods to connect to ASIAIR by using an iPhone.
Using WiFi
There are two methods to connect with Wi-Fi. The first is the AP mode which we are familiar with, another is the station mode, which are available after firmware version 1.4.
Method 1:  AP Mode
AP mode stands for access point mode, using the direct wireless connection broadcasted by ASIAIR PRO to the device. To use, first power on the ASIAIR PRO, and wait for 15 seconds, make sure the red PWR light is on, the green CARD light is flash, and “Wi-Fi” light is on. Using smartphone or tablet to connect the hotspot name similar as “ASIAIR_XXXXXXXX”, the default password is “12345678”, and tick “Keep Connection”, then open the ASIAir app.
WiFi setting-ASIAIR PRO
When the following user interface appears, choose all the appropriate devices, and tune related settings, then click “ENTER”.
confirm page-ASIAIR PRO
This is the most common and fundamental way to connect to ASIAIR PRO. Due to the limited coverage and easy to be interfered with obstacles of the Wi-Fi hotspot, your smartphone or tablets cannot be far from the ASIAIR PRO. To extend the coverage of the Wi-Fi hotspot, you may buy a Wi-Fi repeater, or choose another way to connect: Station Mode.
Method 2: Station Mode
STA mode stands for station mode. The station mode could not only extend the Wi-Fi coverage, but also resolved an issue appear on only parts of Android phones: Those phones cannot access the Internet after connected to ASIAIR PRO.
Using station mode, and connect ASIAIR PRO to your Wi-Fi network, the wireless router will bridge your entire Wi-Fi network. You could control the ASIAIR PRO within the coverage of your Wi-Fi network, which obviously covers more area than a single Wi-Fi hotspot. And you could access the Internet at the same time.
Here is how to do it:
First connect ASIAIR PRO as the first method, then find “WiFi Station Mode” under ASIAIR PRO Settings and enable it.
WiFi Station Mode-ASIAIR PRO-1
Please be advised, the station mode only supports for 2.4GHz.
WiFi Station Mode-ASIAIR PRO-2
Then select the Wi-Fi network you want to be bridged and enter the password if necessary.
You have finished configuring station mode of ASIAIR PRO.
You can view IP Address and other network-related settings after you tap the “info” button in the rightmost.
WiFi Station Mode-ASIAIR PRO-4
In future sessions, just connect to your Wi-Fi network, open ASIAir app, and double confirm it, then tap “Next”. Now you are connected again!
WiFi Station Mode-ASIAIR PRO-5
Note: Some Android phones or tablets may require you to select the Wi-Fi network again.
After you configured station mode, when you open the app, the app will prompt “Reconnecting” when you are in the coverage of your entire Wi-Fi network.
And if you have multiple ASIAIR PROs in station mode, you do not need to go back to the first step, just tap “Switch Device” in “ASIAIR PRO Settings”, there will be a list for you to switch different ASIAIR PROs.
WiFi Station Mode-ASIAIR PRO-8
WiFi Station Mode-ASIAIR PRO-6
The device name in the list could also be renamed for better identification.
In real world, we strongly recommend you use station mode, which could connect your smartphone and tablets to your astronomy rig without coverage restriction. But sometime, the wireless network might not be reliable. At this time, you might try ethernet connection, which more reliable and have higher data throughput.
Using Ethernet
Method 3: LAN Ports
As the WiFi signal might not be very stable sometimes, you can also try the wired connection way to obtain higher-speed and more stable transmission effects.
Connect your ASIAIR PRO to the wireless router with an ethernet cable. Connect your smartphone or tablets to the wireless router. Open the app, you may see “Connected” after “Wired Ethernet” in “ASIAir Settings”.
Wired connection-ASIAIR PRO-1
Tap on “Connected” will display network details. IP Address might be useful if you want to transfer the images out from ASIAIR PRO.
Wired connection-ASIAIR PRO-2
ASIAIR PRO has a built-in Gigabit Ethernet port, which has better reliability and higher data throughput than a wireless connection.
Method 4: Pocket WiFi Router
A Portable Wi-Fi router only has a WAN port, which is also could be connected to ASIAIR PRO. You may set up router based on the instruction of router itself. The portable Wi-Fi router also capable for providing Wi-Fi connection in a small area. You could follow the “Method 3” instruction to set up the network. The “white box” in the following image is the portable Wi-Fi router.
pocket wifi router
Conclusion
  Connection Method Advantage Disadvantage Scenario
Using Wi-Fi AP Mode Easy and fast,
Both 2.4GHz and 5GHz supported
Limited hotspot coverage The phone/tablet close to Wi-Fi Hotspot
Station Mode Can connect to the ASIAIR PRO box in the coverage of your entire Wi-Fi network Only support 2.4GHz The phone/tablet and astronomy rig could be covered by the same Wi-Fi network
Using Ethernet LAN Ports Fast and reliable,
Gigabit network
Limited by the length of the ethernet cable The astronomy rig is near the router
Pocket WiFi Router Combined with Ethernet and Wi-Fi, providing flexibility connection You have to pay for it first None
All 4 methods have their own pros and cons. You may choose the most fitted ones.
79 Comments
  • Yuntao Lu
    Posted May 4, 2020 at 10:12 pm
    I cannot connect ASIAir Pro to my home wifi network. My home wifi is using Net Gear Orbi mesh, I can find WiFi SSID from the list, when I input password, after several seconds, it said connect failed. I also tried to “disable” 5G network, but the issue is still the same.
    • Post Author
      Moson
      Posted May 6, 2020 at 3:21 am
      You could try the wired connection way to obtain more stable transmission effects.
  • MikiSJ
    Posted May 29, 2020 at 7:28 pm
    Can this AIR be used on a laptop using the Windows 10 Pro O/S?
    If so, then what is the speed of the LAN when connected via Ethernet?
    • Post Author
      Moson
      Posted June 1, 2020 at 7:21 am
      Sorry the ASIAIR can not be used on a laptop, maybe you could install Android virtual machine on your laptop. And the speed of the LAN is depend on your home net and wire cable.
  • Chris
    Posted June 17, 2020 at 2:47 pm
    My home network has no password, the station connection will not allow me to continue without a password. How can I connect to a open wifi network with no password?
    • Post Author
      Moson
      Posted June 18, 2020 at 8:36 am
      You could connect ASIAIR with your home network directly first, then choose the station connection. And you must click your open wifi network in the ASIAIR manually. After that, you need wait for a while. The ASIAIR PRO will connect to your open wifi network.
  • Torben
    Posted June 25, 2020 at 10:12 am
    Hi I am having the same problem on my home wifi as Yuntao – I can see the network but it does not connect – is this something that can be fixed?
    • Katherine Tsai
      Posted July 6, 2020 at 10:56 am
      Please try keeping close to ASIAIR device and Home wifi both.
  • Christian
    Posted July 12, 2020 at 6:53 am
    i have the white box in the photos my network shows but it says that it can not conntect like my password is wrong or something.
    It does show wired connected but my phone shows connected yo asair pro.
    So im confused. In the wifi setting on the app it has the white box as saved. But when i choose to connect to it. It ask for a password then it fails all the time.
    • Katherine Tsai
      Posted July 14, 2020 at 8:22 am
      Please keep closer to your ASIAIR device and try again, if the problem not solved, you can send us an email to support@zwoptical.com
  • Gerald
    Posted July 30, 2020 at 10:32 pm
    If i use your 64 GB thumb drive I dont have the ports I need to operate. I need one main camera one to guide one to focus one for mount. So what would you recommend I have a Pegusus box pro do you recmmend it to be used?
    • Katherine Tsai
      Posted August 2, 2020 at 5:50 am
      You can add a hub or use the USB2.0 hub on cool camera.
  • Karian
    Posted August 30, 2020 at 11:09 am
    Hi.
    I can’t use internet when I use ASIAir Pro by android phone.
    I changed my phone’s IP settings from DHCP to static but it has no effect.
    How can I use internet when I using ASIAir Pro?
    • Post Author
      ZWO.Moson
      Posted August 31, 2020 at 3:05 am
      You can connect your ASIAIR PRO to your family internet, change the connection mode in the ASIAIR app to Station mode.
  • Rayschilke
    Posted October 1, 2020 at 1:36 pm
    Is it possible to connect my laptop to the asiair pro so I can see my larger sceen?
    • Post Author
      ZWO.Moson
      Posted October 9, 2020 at 1:53 am
      Sorry the ASIAIR PRO can not connect laptop. You can use the ASIAIR PRO via iPad.
      • Filipe
        Posted October 9, 2020 at 9:06 am
        If I bought an ASIair I could be happy with using it to setup and control some sessions using an iPad provided I could at other times feed the connected cameras through to a PC via the WiFi or wired Ethernet. In this mode it would act as a camera hub. The icing on the cake would be to have the LiveStacking available as a video stream. Being able to view images on a large high resolution monitor is important.
        Phil
        • Post Author
          ZWO.Moson
          Posted October 10, 2020 at 3:33 am
          I will convey your feedback to our devs, and they will consider this.
      • Mike
        Posted December 18, 2020 at 5:17 pm
        I connect to AAP with my 10″ Galaxy Tab A tablet. The tablet has the ability to cast its screen to any smart TV. Now, we can sit in our living room and watch the proceedings on our 55″ flat screen smart TV. Cool!
    • Stuart
      Posted November 8, 2020 at 10:01 pm
      Yes you can do this is Download an Android Emulation like BlueStack . On the BlueStack application Download ASI AIR Mobile App. Good Luck .
      I am trying to Get 3 ASI AIR Pros to Connect to home Network. This way I can Control Three Telescopes No luck yet
    • Nestor
      Posted January 30, 2021 at 2:27 pm
      Yes, just download NOX android emulator then install ASIAIR app in it. Works great faster longer range than a tablet.
  • NP
    Posted October 12, 2020 at 2:49 am
    Can You change the default wifi password on the ASIAIR PRO ?
    I can see this can be an issue at star parties if there are other ASIAIR units near by.
    • Post Author
      ZWO.Moson
      Posted October 12, 2020 at 2:58 am
      Sorry the wifi password can not be changed.
  • Johnie
    Posted October 15, 2020 at 2:44 am
    Is it possible in the future to have also 5Gh support in Station Mode?
    • Post Author
      ZWO.Moson
      Posted October 15, 2020 at 10:23 am
      Sorry it is impossible to develop the 5Gh in Station Mode due to the hardware limitation of raspberry pi4.
      • Bobby
        Posted December 13, 2020 at 6:37 pm
        When I put the the device into Station Mode it keeps auto reconnecting all the time. I have tried to put the unit in 2.4ghz but on auto reconnect it switches it back to 5ghz. Then keeps auto reconnecting.
        • Post Author
          Support@ZWO
          Posted December 14, 2020 at 10:04 am
          Please upload the log in APP Feedback for us to analyze.
  • Georg Nyman
    Posted October 16, 2020 at 8:43 am
    I use the pocket router as shown in your photos. It works fine, but I had to place it in such way, that it stays unobstructed by the mount and /or telescope. Like that, I get good signal strength for all scope positions. WIFI signal of the ASIAIR Pro is too weak to bridge the distance from my scope position in my garden to my living room (about 15m).
    • Post Author
      ZWO.Moson
      Posted October 19, 2020 at 6:15 am
      You can also try to use Ethernet.
  • Markus
    Posted October 16, 2020 at 1:07 pm
    I have a Celestron AVX and Skylink Module. Is it possible to connect the mount via WiFi (via the Skylink) to the ASIAIR Pro? Perfect would be station mode, WiFi to mount and SkySafari on iPad.
    • Post Author
      ZWO.Moson
      Posted October 19, 2020 at 6:22 am
      Sorry we haven’t test this connect way before. We suggest you use hand control and USB cable.
  • Pamela
    Posted October 21, 2020 at 3:14 am
    Hi, is it possible to use ASIAIR PRO with my phone in the middle of the dessert, no wifi connection?
    • Post Author
      ZWO.Moson
      Posted October 22, 2020 at 7:56 am
      Yes, it does not require network when connect the ASIAIR PRO to your phone.
  • Don
    Posted October 21, 2020 at 5:28 am
    I second that request. I have all asi cameras and two eaf but would hate to be restricted to
    a tablet interface 100% of the time. Love your products but this limitation is a deal killer
    Don Singer
    Portland, OR
    • Post Author
      ZWO.Moson
      Posted October 22, 2020 at 8:28 am
      You can leave away from the ASIAIR app when you start the auto run.
  • Terry D.
    Posted October 23, 2020 at 12:52 am
    I am able to connect to the ASIAIR PRO through direct ethernet connection and through station mode, but I can not connect directly through AP mode.
    I’m using an iPhone 7 with latest software. My phone connects to the wifi network, but when I run the app it cannot find the network.
    I have tried to reset but it does not fix the issue. How do I fix this AP connecting issue?
    Thanks.
  • William
    Posted November 7, 2020 at 3:16 pm
    I am ready to purchase an ASIAIR, and a ZWO ASI 385 MC.
    My home has 3 WIFI networks on 2.5 and 5 Ghz bands. I wish to connect with multiple Android tablets, meaning 2 at the same time. 1 for controlling the scope, and cameras, and a larger 18″ Samsung Galaxy View 2, just for previewing images (EAA), indoors during colder weather. Just want to know if this is possible.
    SECONDLY. The Galaxy View 2 currently runs Android 8.1. Google Play will not allow me to install the ASIAIR app. I went thru this years ago with my Galaxy View 1. It was a matter of catching up to the devices from Google. My View 2 runs Sky Safari Pro V6 effortlessly. Is there another method to install the ASIAIR app into the Galaxy View 2? A bigger screen is by far better!
    • sara.liu
      Posted November 12, 2020 at 8:15 am
      Hi William,
      1. AIR allows two devices to be connected, but does not provide simultaneous operation of two devices. One device is enough, it can be controlled and previewed.
      2. GooglePlay has restrictions on the installation of software. There are many restrictions, such as region (for example, prohibited in China), device hardware (devices with non-general Android systems), software version (over-old system version), age (minor) Protection) and so on.
      At present, the distribution area of our APP is: global, the age limit of Google account is: 3 years old +, and the supported system version is: 5.0 and above.
      If it is a popular model and the network status is normal, there should be no problem with the installation. If there is problem, please download the APP on our English official website .
  • John holmes
    Posted January 29, 2021 at 4:49 pm
    Right hope someone can help I just got a new ioptron cem26 with built in WiFi as well as a hand control
    Now how do I connect it to the asiair pro which telescope mount do I pick? Anyone please!!!
    • Post Author
      Support@ZWO
      Posted February 3, 2021 at 7:19 am
      Please try hand control first.
  • 배소한
    Posted January 30, 2021 at 10:18 am
    Hi.
    Can ‘Airpro’ power ‘eaf’ and ‘294mc pro’ and ‘120mm mini’ simultaneously?
    • Post Author
      Support@ZWO
      Posted February 2, 2021 at 10:03 am
      We recommend a 12-15V 2-6A power supply. ASIAIR PRO uses 2A while working alone, and the power supply should be able to power all device that connects to ASIAIR PRO.
  • Allen
    Posted February 5, 2021 at 10:59 pm
    New, just bought the ASIair Pro. Air pro will not connect through Wi-Fi. Used LAN to connect, it worked. Firmware update loaded but will not install, “Installing Firmware Failed”. I rebooted and started all over again. No Wi-Fi, and will not install firmware.
    Now my tablet is communicating with it, but the LAN to air pro is needed.
  • James Goodall
    Posted February 11, 2021 at 10:00 pm
    Okay, I really like the ASIAIR Pro!
    I have an important request. When I’m imaging with my fast f2 HyperStar 11″ Edge the guiding dither and settling eats up way too much time! I have an iOpton CEM60 EC which is a really good tracking mount and it’s adjusted nicely, but it always overshoots a time or two (occillates) when re-acquiring stable guiding so I’m wasting very precious imaging time. Otherwise my guiding is great with that mount, it’s just the settle time. I probably don’t even need to guide because because of the short exposures, but then I can’t Dither which is super important!
    Can you at least offer a dither setting without the guiding feature for fast scopes and good mounts?
    Another better (but perhaps more challenging) solution perhaps is to drop the guide exposures just for dithering and star re-acquisition from every 3 seconds (or so) to perhaps .5 – 1 second. Then of course go back to the 3 second guiding on the guide star imaging, but the camera gain would certainly need to be dropped at the same time or the star would be grossly over saturated…changing the guiding aggressiveness messes with my normal guiding too much causing overshooting then.
    Thanks for the amazing ASIAIR and keep up the helpful programming!
    • Post Author
      Support@ZWO
      Posted February 15, 2021 at 2:02 pm
      Hello james
      Thanks for the feedback
      We will convey this to our R&D
  • frankie
    Posted February 12, 2021 at 2:02 pm
    How can I get the ASIAIR Pro to save pictures in 16 or 32 bit? They seem to only be saved in 8Bit. I am using the ZWO533 MC camera. Also, after downloading the pictures, they are as tiny as can be. Is this because of the 8Bit?
    thanks for your help
    • Post Author
      Support@ZWO
      Posted February 13, 2021 at 11:46 am
      Hello
      The fits file saved 16bit
      the video (avi)saved 8 bit
  • saturnobservatory
    Posted March 5, 2021 at 4:30 pm
    Hi, this is the first time I use my ASI294MC with the ASIAIR Pro and while imaging I found the screen full of RGB noise!! What could be the reason? Do i need to change any setting in the ASIAIR Pro? I’m using this camera for the last one year and never faced this issue with any imaging software
  • Nikolay
    Posted March 7, 2021 at 12:36 am
    When can we finally get support for our existing focusers like Moonlite etc.? I see the same question has been asked for years by other users. I am sure ZWO will sell a lot more ASIAIR units if other focusers are supported.
    • Post Author
      Support@ZWO
      Posted March 8, 2021 at 9:59 am
      There is no such plan. Please buy ZWO EAF.
  • Dany
    Posted March 11, 2021 at 2:34 pm
    I can connect with the ap mode but, when I try to connect to my wifi with station mode it doesn’t behaves as explained in the article. After I inserted the Wi-Fi password it lost connection e wasn’t able to pass the password to asi air pro. After sever times closing the app and do it again it seems to save the network but when I go out of range of the asi air pro it lost connection . If I connect to the Wi-Fi the app doesn’t see the asi air pro… I’ve tried all day long. Can you help me?
    • Post Author
      Support@ZWO
      Posted March 12, 2021 at 8:41 am
      What is your mount? Please send mail to support@zwoptical.com and we can send you some instruction.
  • Mike
    Posted March 20, 2021 at 9:51 pm
    Will the asiair pro ever get an update for the Meade lx85 mount?
    • Post Author
      Support@ZWO
      Posted March 22, 2021 at 9:48 am
      Meade lx85 is supported.You can choose “Meade LX200 Classic” or “Meade LX90/200/600/850 ACF/GPS”.
  • Marcel
    Posted March 31, 2021 at 11:03 am
    I decided not to buy Asiair pro because of the many reported issues with WiFi. I will wait for the final resolution of the wifi problems and also the addition of the Bleutooth capacity. thank you
    • Post Author
      Support@ZWO
      Posted April 3, 2021 at 2:36 pm
      Hello
      why did you need the Bluetooth?
  • Phil
    Posted April 6, 2021 at 3:03 pm
    Hello,
    I was reading that the AsiAir can connect to two devices.(Phones/Tablets) What would that entail? Would one device act as the ‘system operator’ with all the controls while the other device works as a ‘viewer’?
    Thanks,
    Phil
    • Post Author
      Support@ZWO
      Posted April 7, 2021 at 8:38 am
      Sorry to tell you that you can’t operate like this.
  • Zummerzet_Leveller
    Posted April 16, 2021 at 11:03 am
    Is it possible to change the wifi channel on the ASIAIR Pro? Mine is on Channel 11 and conflicts with other wifi signals in the area.
    • Post Author
      Support@ZWO
      Posted April 19, 2021 at 9:57 am
      Channel 11 is default and can’t be changed.
  • Greg
    Posted July 6, 2021 at 1:56 am
    I love the idea of the station mode, but I can’t seem to get it to work. It asks me to enter my WiFi password, but rejects it every single time. I tested my password by disconnecting my phone from the WiFi, then reconnecting using the same password and it works. I suspect that there’s either a bug, or it’s only capable of a specific network encryption type. Does anyone know which specific network encryption type(s) it supports? Also, it doesn’t seem to have an antenna, I am wondering if one can be added, or what is the max distance it can be from the router. I’m having similar issues with the station mode on my Star Adventurer Pro, and there doesn’t seem to be much troubleshooting guides yet.
    • sara.liu
      Posted July 7, 2021 at 3:38 am
      Please separate SSID for 2.4 and 5ghz, connect the 2.4ghz.
  • pom
    Posted August 5, 2021 at 2:35 pm
    Can celestron astro fi connect to wifi with zwo asi air pro? If zwo asi air pro can do .how to do it?
  • Cuende
    Posted September 13, 2021 at 6:54 am
    Is it possible to connect an adaptador Wifi USB to ASIAIR PRO to solve communication coverage problems? Like BrosTrend 650Mbps Linux Adaptador WiFi USB or similar.
  • Alessandro Galdiero
    Posted October 18, 2021 at 1:17 pm
    Sarebbe possibile ricevere un manuale con la spiegazione di come si usa asiair tutte le funzionalità.Grazie
  • piotr.kryger
    Posted November 3, 2021 at 10:14 pm
    Hi
    I would like to ask if asiair pro or plus has an option to connect to the mount via bluetooth?
    • sara.liu
      Posted December 1, 2021 at 9:23 am
      No, we will consider your request.
  • juan gonzalez
    Posted November 13, 2021 at 5:39 am
    Como puedo transmitir por redes sociales la aplicacion de AsiAir como por ejemplo en un facebook live¿?
  • Candice
    Posted December 19, 2021 at 11:28 pm
    Can you use the asiair for observation?
    • sara.liu
      Posted December 20, 2021 at 10:14 am
      ASIAIR PRO is a smart WiFi device.
  • Gerald J Dubesa
    Posted January 3, 2022 at 3:15 am
    I can connect in AP mode using my iPhone, but I cannot connect in AP mode using my iPad. I did not purchase cellular data with my iPad. Do you need cellular data on the iPad to connect in AP mode?
    Jerry
