New filter Drawer for Nikon lens
New filter Drawer with a thickness of 29mm that can be used for carrying 2” filter and connecting ASI cooled cameras to Nikon Lens.
It is compatible with all ASI cameras with 17.5mm back focus distance (except ASI GT series): 1600/294/183/071/533/2600/6200/2400
It can be used with all ZWO 2” filters, including the duo-band filter, narrowband filter, IR-cut filter, etc.
If you are using 2” filters from third party, then please make sure they meet the requirements below.
Filters are very easy and convenient to install and pull out with the ability of double strong magnetic adsorption.
Thread of the interface: M42*0.75.
You’ll need use a M54M-M42F adapter (0mm) to connect the filer drawer to the full-frame camera.
Connection method
Connecting to ASI1600/294/183/533:
Connecting to ASI6200/2400/2600/071:
*The M54M-M42F adapter is needed when connected to full-frame camera ASI6200/2400.
Mechanical drawing
70mm diameter*29mm(thickness)
M42*0.75 male (external) thread (camera side)
M48*0.75 female (internal) thread (filter end)
Suitable for 2-inch astronomical filters
What’s in the box?
New filter Drawer for EOS lens
The New filter Drawer for EOS Lens,26.5mm thickness is independently designed by ZWO and specifically made to match with ASI cooled cameras and EOS lens. You can freely use the 2” mounted filter with it.
1. It’s compatible with all ASI cameras with 17.5mm back focus length (except ASI GT series).
2. It’s compatible with all ZWO 2” filters, including the duo-band filter, narrowband filter, IR-cut filter, etc.
Below requirements must be met while using the 2” filter from third-party.
3. With the ability of double strong magnetic adsorption, it is more convenient and much easier to install or pull out the filter.
4. The thread of the interface is M42*0.75. You can also use the M54M-M42F adapter to connect the filter drawer to a full-frame camera.
Connection method
1) With ASI1600/294/183/533:
2) With ASI6200/2600/071:
Mechanical drawing
70mm diameter*26.5mm(thickness)
What’s in the box?
